major x20 md62520 battery and gpu wattage problem
36 ANTWORTEN 36
ago89
Nachricht 1 von 37
4.567 Aufrufe
Nachricht 1 von 37
4.567 Aufrufe
Hi everyone, I bought a new notebook medion erazer major x20 md 62520 (MSN30035496) and I'm encountering two problems: 1- the battery not charging specifically, the battery is always at 0% and as soon as I connect the charger the red LED flashes for a few minutes, then remains solid red for a few more minutes and then turns off. The charger works correctly because I tried with a voltmeter and 19.9v comes out as expected
2- there are problems with the in-game wattage of the RTX 4070 video card which does not go beyond 30W of power causing low fps. I checked that the various driver and Windows settings were set correctly or even set "maximum performance" but nothing changed.Another strange thing is that the GPU clock in the menu is correct while in game it drops, and vice versa the percentage of clock usage. Could it be bios related? (i'm on bios 1.07med02 and ec 0.30). I saw a post with a similar problem and it was solved with a bios and ec update https://community.medion.com/t5/ERAZER-Gaming/Erazer-Major-X20-MD62525-NEED-LATEST-BIOS-UPDATE/td-p/...
Can i eventually update bios to gmxpx7xn109med06 and ec GMxPXxx_11.600?
The battery problem doesn't bother me by always using it connected to the AC but I would like to solve the gpu wattage problem as long as it is not related to the battery problem which perhaps does not receive enough voltage to recharge and make the whole thing work properly.
Thanks in advance!
@Major_ToM
36 ANTWORTEN 36
Mastermind
Nachricht 21 von 37
676 Aufrufe
Nachricht 21 von 37
676 Aufrufe
Hi @gasparex & @SolidSnake and sorry for the late reply.
First of all we need to ensure, that both of you have the recent bios version running.
The installation of the N 1.08MED04 in combination with EC 1.07.00 obviously helped and had been linked in this post including an installation guide.
Moreover there is also a version N1.09MED06_EC_1.16.00 available, which can be downloaded here but this would be the 2nd step
+++Installation V N1.09MED06+++
1. Donwload and unzip the file
2. Navigate to the Folder Bios/FirmwareUpdate in Windows environment
3. Right click the file GMxPX7xN109MED06.inf and choose install from the context menue
Machine has to be rebooted for the changes to become effective. Further feedback is really appreciated.
Please also remind, that for any errors, caused by the execution of this update, we don´ t accept any responsibility for damage or lost of data.
Cheers
SolidSnake
Nachricht 22 von 37
631 Aufrufe
Nachricht 22 von 37
631 Aufrufe
Hi, I already did the BIOS and EC update but nothing changed, probably tomorrow I will send the laptop in for repairs. Thank you everyone for the help.
SolidSnake
Nachricht 23 von 37
630 Aufrufe
Nachricht 23 von 37
630 Aufrufe
Devi inviare una mail a xxxx con tutti i dati
Admin edit: Service contact address removed (please note the terms of use)
gasparex
Nachricht 24 von 37
621 Aufrufe
Nachricht 24 von 37
621 Aufrufe
thanks for quick response tom really give me some hope... ive tried to follow the steps but where i get the shell uefi?? ive always doing bios update from bios this new for me.... i dont understand how i should update  @Major_ToM @SolidSnake @ago89 @daddle
gasparex
Nachricht 25 von 37
608 Aufrufe
Nachricht 25 von 37
608 Aufrufe
appena inviata che ti hanno detto? come si procede? sei riuscito ad aggiornare il bios e il ec?  @SolidSnake
GialloGiallo6
Nachricht 26 von 37
593 Aufrufe
Nachricht 26 von 37
593 Aufrufe
Ciao ho lo stesso identico problema. Hai risolto dopo l'assistenza?
GialloGiallo6
Nachricht 27 von 37
590 Aufrufe
Nachricht 27 von 37
590 Aufrufe
Io conosco il problema del fatto che la batteria non viene caricata ma vorrei prima sapere se tramite l'assistenza hai risolto. @SolidSnake
Tags (1)
SolidSnake
Nachricht 28 von 37
576 Aufrufe
Nachricht 28 von 37
576 Aufrufe
Ancora devo spedirlo in assistenza, aspetto che mi inviano l'etichetta per la spedizione e, come ho già detto, ho aggiornato il BIOS e l'EC ma il problema è rimasto uguale.
GialloGiallo6
Nachricht 29 von 37
546 Aufrufe
Nachricht 29 von 37
546 Aufrufe
Sono felice che tu mi abbia risposto. Io invece credo che lo restituirò. Adesso ti spiego cosa c'è di preciso che non va. Ho aperto il portatile e ho fatto alcune misurazioni con il tester. Ci sono 2 linee di voltaggio che arrivano alla batteria una è da 16v (quella che serve per caricare la batteria) e un altra è da 3v( comunicazione scheda madre batteria). Purtroppo la linea da 16v non arriva completamente ai connettori della batteria. Avevo anche sentito un leggerissimo odore di bruciato nei pressi della batteria ma non sono riuscito ad individuare il componente rotto. Che peccato il portatile sembra veramente bello. Ma il danno è molto grave. @SolidSnake
gasparex
Nachricht 30 von 37
510 Aufrufe
Nachricht 30 von 37
510 Aufrufe
Mi spieghi come aggiornare il BIOS e ec??? @SolidSnake
36 ANTWORTEN 36
