major x20 bios
3 REPLIES 3
valleron2009
Message 1 of 4
Message 1 of 4
major x20 bios
hello,i have medion erazer major x20 laptop.Does the bios from this post is compatible with mine machine even if i have different msn
ERAZER Major X20 (MD 62520) NL
MSN: 3003 5466
https://community.medion.com/t5/ERAZER-Gaming/Erazer-Major-X20-MD62525-NEED-LATEST-BIOS-UPDATE/td-p/...
2)Do you  have updated bios and firmware ,i mean newer versions?
1 ACCEPTED SOLUTION
Message 3 of 4
Message 3 of 4
Hi @valleron2009 ,
on the one hand we´d like to know which Bios version you´re currently operating with, but the version you linked is the last one we provided.
If there are further questions to be asked, you can feel free to do it.
Cheers
3 REPLIES 3
Message 2 of 4
Message 2 of 4
@valleron2009
Yes, it should. It has got the same mainboard / BB TFG GM6PX7X Major X20 ERAZER bk.than the other PC in your link.
But first please check with @Major_ToM to be 100% sure and state the MSN number of your PC.
Major, would you be so nice, as always? 🙂
Cheers, daddle
Message 3 of 4
Message 3 of 4
Hi @valleron2009 ,
Cheers
valleron2009
Message 4 of 4
Message 4 of 4
I had bios version 1.07 I think and ec 0.30.But  I updated with the new one that you provided.it was a little hard to find how to flash ec but I managed. All OK thanks. SOLVED
3 REPLIES 3
