ddr5 on erazer deputy p60
11 REPLIES 11
Mouth07
Message 1 of 12
Message 1 of 12
Hello everyone,
I purchased an Erazer Deputy P60 (MD62594) equipped with an Intel i5 12450h processor and 16GB of DDR4. The technical documentation states that the Intel i5 processor supports DDR5 RAM, but there is no information provided regarding motherboard compatibility.
Since I want to upgrade the RAM to 32GB, do you know if the Deputy P60 supports DDR5?
Thank you very much!
2 ACCEPTED SOLUTIONS
Message 6 of 12
Message 6 of 12
@Mouth07
Main memory is any part of RAM, small or total, independent from the slot it is put it in..But you are a bit stubborn, aren't you?
The manual and the service page tells you 32 GB is the maximum RAM which can be installed! In total!
Service page:
  • Hauptspeicher: ( main memory)  2x 8192 MB DDR4 SO-DIMM (PC4-25600/ 3200 MHz) (2/2 Slots covered; 32 GB max.)
@daddle  schrieb:
You could try to insert 2 modules, 32 GB each. But the PC was only testet with 2 x 16GB RAM
Sorry, but If you do not believe me nor the Medion technical facts, you shouldn't   ask here at all.
Sorry, but that is how  it is.
Message 11 of 12
Message 11 of 12
@Mouth07
No we do agree in so far that the boardmanufacturer designed the board for 64 GB; Medion takes it over, a so called OEM Board resp. PC, and fits it with 32 GB.
May be they did change something in  chipset or bios.That's why I did write, try 2 x32 GB, it could work.
But Medion only tested up to 2x16 GB.
But now enough in waste of time
JUST TRY What for do you actually need 64 GB? It only costs more battery endurance.
Cheers, daddle
11 REPLIES 11
Message 2 of 12
Message 2 of 12
Hello @Mouth07 and welcome.
The processor supports both DDR5 and DDR4.
But the slot on the board NP50RND1 is physically designed only for DDR4 (different notches).
bye Fishtown
Mouth07
Message 3 of 12
Message 3 of 12
Thank you so much.
So the limit of the motherboard/I5 is  32 go with 3200Mhz, is it right ? No hope to push to 64go ?
Regards.
Message 4 of 12
Message 4 of 12
@Mouth07
Check  the Technical Data:
-->https://www.medion.com/de/service/product-detail/30039966
If your MSN differs, you can call for it. But the technical data are the same.
Cheers, daddle
Mouth07
Message 5 of 12
Message 5 of 12
Thank you for the answer.
I found the notebook manual on the forum.
For the RAM it is written : "The computer has four memory sockets for 260 pin Small Outline Dual In-line Memory Modules (SO-DIMM) supporting DDR4 Up to 3200 MHz. The main memory can be expanded up to 32GB. The total memory size is automatically detected by the POST routine once you turn on your computer. "
My english is not perfect. When it is written "the main memory" it means the total capacité for the 2 slots or the maximum capacity of each slot ?
Regards
Message 6 of 12
Message 6 of 12
@Mouth07
Service page:
Mouth07
Message 7 of 12
Message 7 of 12
Ok it is clear thank you !
Message 8 of 12
Message 8 of 12
Hi @Mouth07
@Mouth07  schrieb: So the limit of the motherboard/I5 is  32 go with 3200Mhz, is it right ? No hope to push to 64go ?
According to Intel, your I5-12450H can: Max Memory Size 64GB Memory types/ Up to DDR4 3200 MT/s /https://www.intel.com/content/www/us/en/products/sku/132222/intel-core-i512450h-processor-12m-cache-...
according to the clevo service manual (you have a barebone clevo NP50RND1)
you can install up to 64 GB of RAM.
bye Fishtown
Message 9 of 12
Message 9 of 12
@Fishtown
Das is bekannt. Deswegen hatte ich ihm geraten, es mit 2x 32 GB module zu versuchen.  Auch wenn Medion nur bis 32 GB insgesamt getestet hat.
Außerdem weiss man nicht sicher , ob nicht in der Medion - oder OEM Version doch Abänderungen am Chipsatz  oder im Bios  gemacht wurden, die den Speicher limitiert.
Bye, daddle
Mouth07
Message 10 of 12
Message 10 of 12
Thank you so much.
I am a little bit confused because you are not agree with daddle. But he also provide reference to technical information....so now the information depends on what we read...
I think the best thing to do is to try with 64 go and waiy for the result.
Regards.
11 REPLIES 11
