X7851 Control centre disappeard
3 REPLIES 3
devonaygo
Message 1 of 4
Message 1 of 4
Recently I noticed Control centre has vanished from my PC, I have tried reinstalling and the installer appears to run as normal but control centre does not appear on my PC, any hints or ideas as I can no longer control CPU clocking, Fan speeds, user profile & RGB
3 REPLIES 3
Message 2 of 4
Message 2 of 4
Hi @devonaygoand welcome
not activated? try either:
Fn + /        = Launches the application Control Center
bye Fishtown
You can find the control center software by entering your MSN number on the Medion service pag:
https://www.medion.com/de/service/product-detail/30025239
You have a barebones Clevo P670 HP6-GM this still found at clevo in the user manual:
https://www.clevo.com.tw/en/e-services/download/ftp_download.asp?sno=6680&no=3
there is in side B-2:
To run the Control Center press the Fn + Esc key combination, or double-click the icon in
the notification area of the taskbar. Close the Control Center by clicking the close icon in
the top right of the panel (move the cursor onto the top right corner of the panel to highlight it).
devonaygo
Message 3 of 4
Message 3 of 4
Hey thanks for replying. I had version 50001.1.12 installed as when I ran the installer it offered to modify, repair or remove it I have tried repair and uninstalled and reinstalled both versions:
50000.0.24 installs, restarts then says fix the installation & restart, this repeats in a loop
50001.1.12 installs without error but will not appear in task bar nor when pressing FN ESC
so still stumped?
Mastermind
Message 4 of 4
Message 4 of 4
Hi @devonaygo ,
sorry for the late reply. Did you already fix your problem,or are you still in need of any assistance?
In this case pls let me know by tagging me with an @signe before my username, so that I receive an automatic notification about your answer.
Cheers
3 REPLIES 3
