X6805 Performance With External Display
3 REPLIES 3
Jimster71
Message 1 of 4
Message 1 of 4
Hi,
I was playing Forza Horizon 4 with my X6805 connected to my 1080p TV via HDMI. I noticed I was getting a lot of stuttering and frame drops.
I had just the external display selected so the laptop screen was off.
I normally get 60fps at 1080p on the laptop screen, but it seemed to be struggling with the 1080p TV.
Any suggestions?
Thanks,
J
1 ACCEPTED SOLUTION
SlamRam
Retired
Message 2 of 4
Message 2 of 4
Hey @Jimster71,
What TV are you using and what resolution does it have? It may be that if your TV is running at a higher res, it will use more GPU and therefore cause FPS issues.
Cheers!
SlamRam
MEDION AG - A Lenovo Company • • Community: community.medion.com
Please reward helpful posts with Kudos and mark solutions with Accept as solution.
3 REPLIES 3
SlamRam
Retired
Message 2 of 4
Message 2 of 4
Hey @Jimster71,
Cheers!
SlamRam
Jimster71
Message 3 of 4
Message 3 of 4
Hi,
The TV is a Sony Bravia 40" 1080p 60hz model, running in Game Mode.
I tried it again last night and the performance seemed ok. I'm wondering if it was to do with the order that things were done last time.
Cheers.
GarciaBarnes
Message 4 of 4
Message 4 of 4
How powerful the graphics processor in the laptop is. You might notice a fall in performance, you might not.
iMessage For PC
3 REPLIES 3
