X15809's USB-C support external displays?
3 REPLIES 3
FunkyMonkey95
Message 1 of 4
Message 1 of 4
Hello,
Like the title says, does the USB C port on the back of the laptop (x15809, MSN: 30027171, MD: 61598) support display over USB? Thanks in advance.
2 ACCEPTED SOLUTIONS
Gehringer
Retired
Message 2 of 4
Message 2 of 4
Hi @FunkyMonkey95 ,
as per my research on the user manual, the universal serial bus ports on your unit are standard for connecting input devices, not working as a display output.
Regards,
Gehringer
Message 3 of 4
Message 3 of 4
Hi @FunkyMonkey95 ,
doublechecked the topic and @Gehringer is absolutely right.Machine has 2 USB 3.1 ports type A and one type C, which definitely is just a data port and has not support for Power Delivery or Display Port function.
Cheers
3 REPLIES 3
Gehringer
Retired
Message 2 of 4
Message 2 of 4
Hi @FunkyMonkey95 ,
Regards,
Gehringer
Message 3 of 4
Message 3 of 4
Hi @FunkyMonkey95 ,
Cheers
FunkyMonkey95
Message 4 of 4
Message 4 of 4
Cheers @Gehringer & @Major_ToM . Appreciate it. 🙂
3 REPLIES 3
