op 09.09.2024 19:22
op 09.09.2024 19:22
Hello, i have an issue with the temperature felt on the keyboard, my pc is less than 1 years old. I want to know if it is possible to disable the intel arc and so to dissipate less power or anything that can get the things better. Thanks.
op 12.09.2024 10:08
op 12.09.2024 10:08
Hi @giorginho88
Please verify all vents are not blocked and you are using your device on a hard flat surface, the below instructions may assist in disabling intel arc, the Intel site also have options on how to do this
Disabling Intel Arc Control at Startup:
Adjusting Notification Settings:
Uninstall and Reinstall:
Thanks
op 12.09.2024 10:20
op 12.09.2024 10:20
Thanks but i didn't mean to disable the intel arc control, i meant to poweroff the dedicated gpu and stay just with the integrated graphics.
op 12.09.2024 21:15
op 12.09.2024 21:15
You can disable Nvidia Optimus in Control Center in general settings, but I think that does the opposite of what you are asking.
Subject | Author | Posted | |
11.10.2024 15:44 | |||
24.12.2023 21:31 | |||
01.07.2023 21:22 | |||
12.02.2021 14:47 |
