Request for correct BIOS for Medion ERAZER Deputy P50 (MSN 30035503)
5 REPLIES 5
georgefs_
Message 1 of 6
Message 1 of 6
Hello,
I own a Medion ERAZER Deputy P50 (MD62532) with MSN 30035503 and an Intel Core i7-13700HX processor.
Unfortunately, I mistakenly installed the BIOS version 1.07.23RME1 (Insyde) after seeing a forum post stating that it was for the Deputy P50. KBC/EC Firmware Version is 1.07.02ME1. I later realized that the MSN referenced in that post did not match my device even if the model was the same, and I did not notice this before installing it.
Since installing that BIOS, the laptop now takes about 2–3 minutes before the MEDION logo appears, with only a black backlit screen during that time, keyboard lights on and fans turn at slow speed. After the logo appears, Windows starts normally, fans start running accordingly to the control center configuration and so does keyboard light.
I have already tried:
  • Loading Optimized Defaults in BIOS
  • Performing an EC reset (holding the power button for 30–60 seconds with power disconnected)
  • Reflashing the same BIOS version
  • Booting without peripherals
The issue still persists.
Could you please provide the correct BIOS and EC firmware package for my specific unit (ERAZER Deputy P50 – MSN 30035503), or advise which BIOS version is recommended for this model?
Thank you very much for your assistance.
Best regards,
5 REPLIES 5
Message 2 of 6
Message 2 of 6
Hello and welcome!
Please check your information; one of the numbers is incorrect. MD62532 or MSN30035503
Please also provide the link where you downloaded the software.
bye Fishtown
georgefs_
Message 3 of 6
Message 3 of 6
Hello @Fishtown
You are right. Md was wrong. The correct one is MD62538
The link where I got the bios from is: https://cdn.medion.com/downloads/software/00_Bios_Defender_P40_Deputy_P50.zip
Which I found in this forum post: https://community.medion.com/t5/ERAZER-Gaming/Erazer-Deputy-P50-i7-13700HX-thermal-throttling/td-p/1...
Thanks!
Message 4 of 6
Message 4 of 6
Hello @georgefs_
both notebooks are identical except for the keyboard (Spanish-Italian).
Therefore, your BIOS should also be correct.
bye Fishtown
georgefs_
Message 5 of 6
Message 5 of 6
Thanks! @Fishtown
So Is it possible for you to provide an older bios so I can flash it and change it please? Is the EC Version up to date?
Best regards.
georgefs_
Message 6 of 6
Message 6 of 6
Hello @Fishtown is there anyone I can ask for an older bios?
Best regards
5 REPLIES 5
