Replacement fan for Medion ERAZER P10 specialist
2 REPLIES 2
Jonny-boy
Message 1 of 3
Message 1 of 3
Trying to locate a replacement fan for my P10 specialist, but i can't find one anywhere online. Is replacement for the GPU fan covered under warranty, or will i need to keep searching to find one?
1 ACCEPTED SOLUTION
Message 2 of 3
Message 2 of 3
Hi @Jonny-boy and welcome
https://www.amazon.de/RTDPART-Laptop-CPU-GPU-L%C3%BCfter-NP60PNP-NP70PNP-NP71PNP/dp/B0DT6HLDRJ/ref=s...
bye Fishtown
2 REPLIES 2
Message 2 of 3
Message 2 of 3
bye Fishtown
RAZZ
Message 3 of 3
Message 3 of 3
Hi @Jonny-boy
If you contact your local Medion service centre, they’ll be able to confirm the length of your warranty. If the device is still under warranty and there’s no physical damage, the issue should be covered under the warranty. .
https://www.medion.com/gb/service/contact
Thanks,
2 REPLIES 2
