am 05.01.2024 14:40
am 05.01.2024 14:40
Hello, I have bought a new DDR4 ram for my Recon E20. My stock ram was running at around 2800. Now that i added a 3200mhz ram it only runs at 2400mhz. I want to get the max performance of my ram and it seem that i cant adjust it in the BIOS. I need help with making my rams back to atleast 2800-3200mhz.
am 08.01.2024 12:00
am 08.01.2024 12:00
Hi JustVibbin. please first name your PC's MSN number.
And please put the old RAM in again and make a check with CPU-Z. Please quote the RAM MHz
@JustVibin schrieb:My stock ram was running at around 2800. Now that i added a 3200mhz ram it only runs at 2400mhz. I want to get the max performance of my ram and it seem that i cant adjust it in the BIOS.
Compare it to the MHz you r new Ram achieves.
But one more thimg; you say you added a 3200 MHz RAm What does it mean? Did you mix the old RAM with a new modul?
You should be a little more detailed in your explanations of the overall status; and describe in more detail what RAM you bought and which RAM it's mixed with.
A mix of old and new RAM, probably from different manufacturers, usually causes problems.
am 16.01.2024 08:12
am 16.01.2024 08:12
Hi @JustVibin ,
we´re in need of further information from your side, please
Cheers
