RAM question: I have a cpu speed of 2000mhz but I want to put a 16gb 3200mhz ram stick in, is it ok?
2 REPLIES 2
Rkjr
Message 1 of 3
Message 1 of 3
I have a crawler e30 md62547 and I want to put a ddr4 3200mhz sodimm 16 gb ram stick in, I want to know if this is ok for my laptop since my cpu goes at the speed of 2000mhz and also, will it fit? Thank you.
1 ACCEPTED SOLUTION
Message 2 of 3
Message 2 of 3
Hello @Rkjr
You can do that, even up to a maximum of 64 GB.
your current ram also has 3200MHz.
see specification
https://www.medion.com/gb/service/product-detail/30035526
bye Fishtown
2 REPLIES 2
Message 2 of 3
Message 2 of 3
Hello @Rkjr
see specification
bye Fishtown
Rkjr
Message 3 of 3
Message 3 of 3
Thank you , also the link to my ram is here, (if it’s needed) https://amzn.eu/d/3n5QmUg
2 REPLIES 2
