Power light flashing gaming pc x67127
8 ANTWORTEN 8
Confused
Nachricht 1 von 9
4.971 Aufrufe
Nachricht 1 von 9
4.971 Aufrufe
Just moved my pc. Plugged it all in and now the power light keeps flickering inconsistently. It's never done that before. Cant find anything in the manual. Keyboard, mouse and monitor all seem to be connected and are working fine
8 ANTWORTEN 8
Gehringer
Retired
Nachricht 2 von 9
4.970 Aufrufe
Nachricht 2 von 9
4.970 Aufrufe
Hi @Confused,
do you have the MSN number of your PC?
It is an eight-digits number printed in the label near the Medion logo.
You can find it underneath or behind your PC.
It should start by 100, 300 or 500.
Regards,
Gehringer
Nachricht 3 von 9
4.957 Aufrufe
Nachricht 3 von 9
4.957 Aufrufe
@Confused
Did you check your AC wallbox, cable and plug at the back of your PC?
Boots and runs the computer in  normal behavior?
Regards, daddle
Confused
Nachricht 4 von 9
4.953 Aufrufe
Nachricht 4 von 9
4.953 Aufrufe
So far as I can tell it's running fine, started it up and played a few games on it. Power cable is plugged in properly, as are all the internal plugs I could get to. Dont know what an AC wallbox is
Nachricht 5 von 9
4.951 Aufrufe
Nachricht 5 von 9
4.951 Aufrufe
@Confused
Sorry for my english; AC wall outlet?
Confused
Nachricht 6 von 9
4.948 Aufrufe
Nachricht 6 von 9
4.948 Aufrufe
Oh, yeah the connection there is fine. I've had the computer set up here before, just had it at a friends place and brought it back. Nothing so far as I'm aware has changed since then
Gehringer
Retired
Nachricht 7 von 9
4.870 Aufrufe
Nachricht 7 von 9
4.870 Aufrufe
Hi @Confused ,
how's your pc going?
Were you able to solve it yourself?
If so, how?
Please share with us your experience.
Regards,
Gehringer
Confused
Nachricht 8 von 9
4.863 Aufrufe
Nachricht 8 von 9
4.863 Aufrufe
Havent solved it. It's still flickering. But seems to be running fine so I guess it's a problem to be solved when something stops working
Gehringer
Retired
Nachricht 9 von 9
4.821 Aufrufe
Nachricht 9 von 9
4.821 Aufrufe
Hi @Confused ,
I think it may be a connection issue within the light mechanism.
If you want Medion to take a look at it, please contact its technical support team and they may book it for repair.
Regards,
Gehringer
8 ANTWORTEN 8
