New Bios for Medion Erazer P30
38 REPLIES 38
AndyBiker
Message 1 of 39
Message 1 of 39
Hi,
I have an Erazer Deputy P30 notebook.
msn: 30034316
My "old" Bios:
vendor INSYDE Corp.
version 1.07.02RME1_022
Do you know if an updated bios is available?
Where can I find Bios for this Notebook?
Thank you.
38 REPLIES 38
Mastermind
Message 11 of 39
Message 11 of 39
Hi @Kuan ,
due to the many different possible configurations of our ERAZER Crawler E25 laptop systems we´re in need of the eight-digit MSN article number (e.g. MSN 3003xxx ) printed on the underside of the housing.
Cheers
Kuan
Message 12 of 39
Message 12 of 39
Hi,
If i need to down or upgrade my bios where can i find the bios updates or downgrades i have a Erazer Crawler E25 ML210008 and my current version is i think 1.07.04 or 1.07.05 im not sure right as of now so could u guys give the 1.07.04 or the 1.07.05 bios version update so i could update bios or downgrade if needed
Message 13 of 39
Message 13 of 39
@Kuan
As @Major_ToM already wrote, you need o give the MSN number:
"we´re in need of the eight-digit MSN article number (e.g. MSN 3003xxx ) printed on the underside of the housing."And you have to state the exact Bios version.
Cheers, daddle
Kuan
Message 14 of 39
Message 14 of 39
Hello,
Im sorry but i looked under my laptop at the back and there was no MSN or that ther was ML-21008 and serial number + some info about the power adapter and about Product on Product it says NH55EJQ-M ther is No MSN ( MSN 3003xx or something like that)
Message 15 of 39
Message 15 of 39
@Kuan
Chheck with the package it came with, or with the guarantee card. There the MSN number is mentioned as well.
Mastermind
Message 16 of 39
Message 16 of 39
Hi @Kuan ,
like @daddle  already mentioned we need the details about this machine to clearly identify it. Where did you buy it, how does the boxing look. You might additionally provide a photo of your Bios startscreen, but do not forget to remove your personal serial number from this photo.
Cheers
Kuan
Message 17 of 39
Message 17 of 39
@Major_ToM so i checked a few of the thing they are listed below i hope thats ehat u guys need btw its germany bought so i hope the bios flash is also german not really know if it has/does smth to language settings just incase.
Medion Erazer Crawler E25
Product: NH55EJQ-M (ML-210008)
Bios id: NHx0EH
Version: 1.07.05RME1
I want the oldest Bios to flash that is possible with/compatible with my laptop if possible and newest.
Heello6661234
Message 18 of 39
Message 18 of 39
hi i tried to update my erazer deputy P30 MSN 30034316 DICE /NP5XPNP04.efi boot failed
can you tell me what i should do please
Message 19 of 39
Message 19 of 39
@Heello6661234
hallo  6661....
Du müssest uns erst sagen was du mit Aktualisieren meinst, das Bios, oder Windows Updates?
Und jetzt startet er nicht mehr? Booten in Windows oder überhaupt nicht mehr?
Kommst Du noch mit F 2 oder Esc (od.Entf) ins Bios? Dann würde er  ja starten, aber findet die Festplatte oder die Windows Installation auf der Festplatte nicht.
Etwas auskunftsfreudiger musst du schon sein; wir haben hier keine Glaskugel die uns Allles verrät!
Heello6661234
Message 20 of 39
Message 20 of 39
 I just want to update it but it gives me an error, there is another version I can try if it works
38 REPLIES 38
