Memory type for X6807
19 ANTWOORDEN 19
martinmt
Bericht 1 van 20
11.216 Weergaven
Bericht 1 van 20
11.216 Weergaven
Hi
Just bought a X6807 gaming laptop from box  (popular deal this week I think!)
It comes with one 8GB ram stick. I went to scan it at Crucial so I could add a second 8GB and their scan could not identify it. Which was a surprise.
I know it's DDR4 ram - do I need to look for a specific spec of ram though or is it reasonably generic?
Thanks
Martin
19 ANTWOORDEN 19
martinmt
Bericht 11 van 20
5.560 Weergaven
Bericht 11 van 20
5.560 Weergaven
OK thanks, I can see they are offering a Dimm there but it's very expensive at nearly 70eu including shipping. All I want to know is what the generic product is so I can make my own buying decision. It's ridiculous that it's such a mystery.
Bericht 12 van 20
5.547 Weergaven
Bericht 12 van 20
5.547 Weergaven
Hi @martinmt
no mystery,
what kind of ram you got was written to you in post 4 of @TPFLegionaire
if you want to have an exact name read the ram data with:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=2ahUKEwi686PSnuTk...
Bye Fishtown
Blither
Bericht 13 van 20
5.542 Weergaven
Bericht 13 van 20
5.542 Weergaven
Hi - that's helpful, thanks.  I'm using CPU-Z but I'm concerned it doesn't give enough information on exactly what brand is used.  In order to get the additional boost you can get from using two 'identical' (I guess close to is enough) sticks I want to be sure that what I get is as similar as possible.
CPU-Z tells me little more than post 4.  Post 4 is very helpful, though.
https://imgur.com/qI3qsQU
Bericht 14 van 20
5.534 Weergaven
Bericht 14 van 20
5.534 Weergaven
Hi @Blither
look under "SPD" do you have no name/part number there as in this example picture:
Bildergebnis für cpu z spd
Bye Fishtown
Blither
Bericht 15 van 20
5.530 Weergaven
Bericht 15 van 20
5.530 Weergaven
Hahaha I'm an idiot!  I'm so sorry to take up your time with my stupidiy.  Yes, I do...
I'm not sure why my pictures are not showing...
DIMM # 1
SMBus address 0x50
Memory type DDR4
Module format SO-DIMM
Module Manufacturer(ID) Samsung (CE00000000000000000000)
SDRAM Manufacturer (ID) Samsung (CE00000000000000000000)
Size 8192 MBytes
Max bandwidth DDR4-2666 (1333 MHz)
Part number M471A1K43CB1-CTD
Serial number 404ACB21
Manufacturing date Week 32/Year 18
Nominal Voltage 1.20 Volts
EPP no
XMP no
AMP no
martinmt
Bericht 16 van 20
5.525 Weergaven
Bericht 16 van 20
5.525 Weergaven
@Fishtown - thank you that was really useful. I *think* I now have a compatible Samsung  DIMM (and for under £40) so I am ordering and if it is the correct type and size, I'll mark complete and provide a link for others etc.
Bericht 17 van 20
5.523 Weergaven
Bericht 17 van 20
5.523 Weergaven
@martinmt  @Blither
you´re welcome
bye Fishtown
Gehringer
Retired
Bericht 18 van 20
5.440 Weergaven
Bericht 18 van 20
5.440 Weergaven
Hi @martinmt,
we still haven't heard back from you.
Please let us know if your problem is solved.
Regards,
Gehringer
martinmt
Bericht 19 van 20
12.140 Weergaven
Bericht 19 van 20
12.140 Weergaven
Hi there
I am expecting my new DIMM tomorrow and I am confident that this time it will fit and work as the part number is correct.
I bought it from Scan.co.uk in the UK , with tax and delivery it cost about £42
In case anyone wants to look at this - here is a direct link to the product:
http://tidd.ly/baeb3020
Update: Ram received this morning and installed and all sorted. Genuine Samsung Dimm as well.
Thanks
Martin
driver8
Bericht 20 van 20
3.848 Weergaven
Bericht 20 van 20
3.848 Weergaven
Thanks for the informative thread, Martin (and others).
Just for info, in case it helps anyone else.
The Crucial (UK) memory scanner worked OK for me for my X6807 >> my results page at Crucial - and the same thing - as a 3MB png file - and - as a 5MB PDF.
19 ANTWOORDEN 19
