19.10.2024 00:10
19.10.2024 00:10
Hello,
So it appears my Medion P6705 (MD61366) is beginning to fall apart. The 1st issue is on the back cover, some of the screw holes at the top that go into the hinge have failed. The screw goes in, but doesn't stick, so even if it's screwed in, the back cover is still loose in that area. The material that's supposed to hold the screws has broken off.
The 2nd issue is on one side, the hinge no longer screws down because the plastic mounts have broken. So I'm basically in search for chassis replacements. I've looked on the Medion spare parts page and can see some chassis replacements. However, there's no picture for the parts.
What parts do I actually need? Bottom cover and bottom case? I want to make sure before I buy because there's no picture to see if it's actually the part I need.
22.10.2024 10:13
22.10.2024 10:13
HI @Ezenia
If your MSN is 30026124 NB P6705 ERAZER MD61366 UK
here is a list of parts
40068411 NBC BOTTOM CASE CLE N857EK1‑M (bottom cover/underneath of unit)
40068484 NBC BACK COVER MODULE CLE N857EK1‑M (back cover of the screen)
40068418 NBC HINGE RIGHT CLE N857EK1‑M (hinge)
40068417 NBC HINGE LEFT CLE N857EK1‑M (hinge)
thanks
Subject | Author | Posted | |
25.07.2024 09:46 | |||
17.08.2024 15:14 | |||
05.12.2024 10:12 | |||
12.10.2023 19:51 |
