Medion ERAZER hunter x62 RGB LED control
11 ANTWOORDEN 11
Nightslime
Bericht 1 van 12
6.079 Weergaven
Bericht 1 van 12
6.079 Weergaven
Hello.
I have bought myself a nice machine but I don't understand how to control the RGB-fans and front RGB on the chassie.
I have installed the MSI Center but nothing shows up when I press the "Feature Sets" in the program.
The fans are just showing the random color right now but I really want to set only one color instead.
I have contacted MSI support due to the installed MSI-motherboard but they want me to contact Medion support since the Bios have another version according to them.
Someone understand my issue?
Please help.
/RickardMSI center.jpg
1 GEACCEPTEERDE OPLOSSING
Geaccepteerd Solutions
Bericht 10 van 12
4.645 Weergaven
Bericht 10 van 12
4.645 Weergaven
Hi @Nightslime
you are apparently not alone with the problem. here in this post you got it to run as seen in the video, (post7)
https://www.computerbase.de/forum/threads/msi-dragoncenter-mysticlights-wird-nicht-angezeigt.2032699...
the video alone:
https://youtu.be/NUVGEd73QOY
bye Fishtown and good luck
11 ANTWOORDEN 11
Bericht 2 van 12
4.701 Weergaven
Bericht 2 van 12
4.701 Weergaven
Hello @Nightslime  and welcome
there are many hunters with different mainboards there fore you need the MSN number from you regardless.
Mostly under the computer.
Your photo has yet to be approved.
bye Fishtown
Bericht 3 van 12
4.686 Weergaven
Bericht 3 van 12
4.686 Weergaven
Hi @Nightslime
you write MSN Board.
if you have a Hunter x20 / MD35053 / MSN 10024060.
there is an MSI MPG Z490 GAMING EDGE WIFI installed, this is regulated by the Mystic Light:
(Lighting control: housing, mainboard, RAM and fan can be controlled via the MSI® Mystic Light software)
Find it in the MSI Dragon Center
see also here:https://www.msi.com/Landing/mystic-light-rgb-gaming-pc/
bye Fishtown
Nightslime
Bericht 4 van 12
4.680 Weergaven
Bericht 4 van 12
4.680 Weergaven
Hello Fishtown.
My PC have MD 35081  and MSN 10024085 and I have already tried to install the MSI dragon center but the Mystic Light is not there.
I don't understand why it not shows up.
I can only se the temperature of the processor and that kind of stuff but not the Mystic Light....
Bericht 5 van 12
4.673 Weergaven
Bericht 5 van 12
4.673 Weergaven
Hello @Nightslime
I have no explanation for that either.
The only thing would be if you have installed both: msi center and dragon center and this creates a conflict.
Bye Fishtown
Bericht 6 van 12
4.670 Weergaven
Bericht 6 van 12
4.670 Weergaven
@Fishtown  @Nightslime
Hallo Fishtowwn,
vor ab ich habe vom Control Center wenig Ahnung, daher weiss ich nicht ob mein Hinweis (s.u.) hier überhaupt zutreffend ist. Bei meines Sohnes Rechners mit dem gleichem Board in seinem X 15.fanden wir einen gelösten Kabelstecker.
Und ich greife auf einen anderen Beitrag mit folgendem Tipp von Fishtown  zurück, steht mir also kein Verdienst zu,
wenn das die Ursache wäre. 🙂
Hast du @Nightslime  die Kabelanschlüsse intern am Board nachgesehen,und aich den LED Switch auf dem Board kontrolliert ob dieser auf On steht? Siehe Skizze:
Bericht 7 van 12
4.663 Weergaven
Bericht 7 van 12
4.663 Weergaven
Hi @@daddle
Checking the plug when it is not working is always good, but he writes in the first post that you are on, but in rainbow colors. The switch has already occupied me, but it only seems to be for the mainboard, see this post.
https://community.medion.com/t5/ERAZER-Gaming/Erazer-Engineer-X25-LED-L%C3%BCfter/m-p/122411?search-...
Does your son also have the dragon center?
Bye Fishtown
Bericht 8 van 12
4.659 Weergaven
Bericht 8 van 12
4.659 Weergaven
@Fishtown
Da hast du recht, bin nicht zu tief in die Materie eingestiegen. Meine eigenen Sorgfaltsansprüche verletzt. 😳
Aber ob der Switch nur die Mainboard LEDs ansteuert war doch nicht ganz gesichert, oder? Und der Stecker könnte einen Wackelkontakt haben. Ich sagt e ja, es ist nur ein Versuch, von deinem Post damals angeregt.
Was mein Sohn auf seinem Rechner hat muss ich ihn mal fragen; ich kene mich damit nicht aus. Aber er hat das MSI Retail Board MSI B550M PRO-VDH Wifi retail im Rechner; dann müsste es ja die MSI Version sein. (alos das Dragon Center?)
Nightslime
Bericht 9 van 12
4.654 Weergaven
Bericht 9 van 12
4.654 Weergaven
The switch on the motherboard is ON.
I have once again installed the Dragon Center and uninstalled the MSI Center but the Mystic Light still does'nt shows up.
I can se that it installs under the installation process but cant find it anyware in the Dragon Center anyway.
Soo strange??
Bericht 10 van 12
4.646 Weergaven
Bericht 10 van 12
4.646 Weergaven
Hi @Nightslime
the video alone:
11 ANTWOORDEN 11
