le 13.03.2024 16:23
le 13.03.2024 16:23
Hi,
My MEDION Erazor P7647 MD 60804 has developed a noisy fan, I have opened the laptop up, could not see anything physically wrong with the fan.
After successfully replacing the Hard Drive and adding an extra memory module, I thought I could do my self.
Look on Amazon for a replacement, but no idea which one to buy.
Could you let me know where to get a replacement or what part number I need to order one.
Secondly looking at the existing fan I noticed there were no retaining screws fitted, not quite sure how to remove the fan or actually fit the new one, is there a video to show the procedure?
If fitting the fan required special knowledge, please et me know where to take it laptop so it can be fixed tyvm
le 13.03.2024 19:15
le 13.03.2024 19:15
Hello @Renme and welcome
Maybe @Dr-Fred can help you, he had the same fan and also had problems removing it, see this post:
Moin @Dr-Fred , kannst du ihn sagen wo er den Ersatzlüfter bestellen kann.
bye Fishtown
le 14.03.2024 11:43
le 19.03.2024 12:44
le 19.03.2024 12:44
I have ordered a fan, when it arrive will investigate how to fit it, apparently tape is needed to secure it, what type of tape do I need?
