MEDION Erazer Hunter X62 (MD35081) randomly reboots
11 ANTWOORDEN 11
Spruce
Bericht 1 van 12
5.248 Weergaven
Bericht 1 van 12
5.248 Weergaven
Hello!
I've noticed that I'm not the only one with this issue. I recently bought this PC only for my excitement to be interrupted by regular, random reboots.
The screen goes black without the PC shutting down and then turns back on like it had just restarted.
Read that it was a BIOS issue and that there was an admin handing out fixed versions of the BIOS. I would be more than pleased to have solution to this.
Current BIOS: E7C79WOX.205   06/11/2021
MSN: 10024085
Waiting for a response,
Spruce.
1 GEACCEPTEERDE OPLOSSING
Geaccepteerd Solutions
Spruce
Bericht 3 van 12
4.173 Weergaven
Bericht 3 van 12
4.173 Weergaven
Andi, an administrator, has sent me a fixed version of the BIOS with steps of installing it. Will be installing it today and testing it out for a couple of days.
Thank you.
11 ANTWOORDEN 11
Bericht 2 van 12
4.112 Weergaven
Bericht 2 van 12
4.112 Weergaven
Hello @Spruce and welcome
you have the same computer as in this post:
https://community.medion.com/t5/ERAZER-Gaming/Medion-ERAZER-X62-MD35081-rebooting-issue/m-p/127451#M...
maybe @Andi (he has been informed) can help you there.
bye Fishtown
Spruce
Bericht 3 van 12
4.174 Weergaven
Bericht 3 van 12
4.174 Weergaven
Thank you.
Spruce
Bericht 4 van 12
4.053 Weergaven
Bericht 4 van 12
4.053 Weergaven
Have been enjoying the limit of my computer for the past week, the BIOS was the problem and Andi sent me (privately) a fixed version of it.
Thank you for the solution!
philarmonix
Bericht 5 van 12
3.965 Weergaven
Bericht 5 van 12
3.965 Weergaven
Hello,
I have the exact same issue since purchase with another model - MD 34941.
Everything works fine except random reboots (usually one every few weeks/at least monthly) even while the pc is idle.
I have those specs :
bios version 460H6W0X.105 19.05.2020
MSN 10023902
I tried an update to version 560H6 but the script I found is not working - maybe it's not the right one.
@Andiif by any chance you can provide some help it would be greatly appreciated
thanks
Bericht 6 van 12
3.961 Weergaven
Bericht 6 van 12
3.961 Weergaven
@philarmonix
Your Mainboard has a B460 Chipset. Of course you can not update your PC with a Bios Update which is meant for the B560 Chipset!.
As far as I know the 460H6W0X.105 Version is the newest for your (and mine) mainboard.
You can try to make a systemfirmware update in Device Manager, but I did to no avail.
But why do you want an Update= The Bios is working fine.
bye, daddle
ConnyAndersson
Bericht 7 van 12
3.648 Weergaven
Bericht 7 van 12
3.648 Weergaven
Hi!
i have the exact same model and issue.
Where can i find the updated Bios or can admin help me?
Bericht 8 van 12
3.633 Weergaven
Bericht 8 van 12
3.633 Weergaven
@ConnyAndersson
If you have a B460H6-EM Mainboard, the following link lets you download it. Courtesy to Majof Tom:-》https://community.medion.com/t5/ERAZER-News/Aktuelles-Bios-Update-f%C3%BCr-die-MEDION-ERAZER-Enginee...
This is Bios Version V. 1.07:
https://cdn.medion.com/downloads/software/00_Bios_b460h6-em.zip
Cheerleader, dsddle
ConnyAndersson
Bericht 9 van 12
3.602 Weergaven
Bericht 9 van 12
3.602 Weergaven
Thanks @daddle
my computer is erazer hunter x62 MD35081, 10024085
my motherboard is;
MPG z490 gaming edge wifi.
do you know where i can find bios update?
Thanks Conny
Bericht 10 van 12
3.597 Weergaven
Bericht 10 van 12
3.597 Weergaven
@ConnyAndersson
Then you have to ask a moderator,  @Andi , and he can tell you which Bios fits your motherboard.
Cheers, daddle
11 ANTWOORDEN 11
