MEDION ERAZER ENGINEER P10 (MD35007)
8 REPLIES 8
MrErnest
Message 1 of 9
Message 1 of 9
Hi, I was wondering if any one can give me a link or pdf file with info on the motherboard that comes with the MD35007? Thanks in advance
Tags (1)
8 REPLIES 8
Gehringer
Retired
Message 2 of 9
Message 2 of 9
Hi @MrErnest ,
Please find below more information about your MB and also some photos that may help you:
ECS B460H6-EM * RAM: max. 32 GB (2 slots) * Form factor: microATX
Interfaces / Connectivity: Back panel:
* 2x USB 2.0 Type-A ports
* 2x USB 3.0 Type-A ports
* 1x DisplayPort
* 1x HDMI
* 1x LAN (RJ45) port
* 3x OFC audio jacks
Internal Connectors:
* 4 x SATA 3 ports (4x black color)
* 1 x M.2 M2_1 (2260 and 2280 size with flexible standoff, SATA mode only)
* 1 x M.2 M2_2 (for PCIe X4 NVMe SSD and Intel Optane module 2260 & 2280)
* 1 x M.2 M2_3 (E-Key 2230 for WLAN only)
* 1 x CPU 4PIN Fan header CPU_FAN (red)
* 1 x Sys FAN 4PIN SYS_FAN (white)
* 1 x Front Audio F_AUDIO with black plastic header
* 1 x Frontside USB: Cardreader with black plastic header (one port only),
* 1 x USB3.0 H10x2 front header F_USB31_12 (Intel pin out)
* 1 x Front_Panel header F_PANEL black plastic header
* 1 x 8PIN ATX 12V connector ATX_12V
PCIe slots:
* 1 x PCIe x16
* 1 x PCIe x1
Regards,
Gehringer
MrErnest
Message 3 of 9
Message 3 of 9
Thats great info. But one last question. I have a commander pro that I want to use with the motherboard if possible. And it needs a USB2 Connector? Is there one on the motherboard? Thanks so much for any answer.
Tags (1)
sweetpoison
Message 4 of 9
Message 4 of 9
Look at the second picture posted by @Gehringer The USB connectors under LAN are USB2.0 (black&white) while the Blue connectors are USB3
On side note, USB3 is build with backward compatibility so can act as USB2 if the connected device requires that.
MrErnest
Message 5 of 9
Message 5 of 9
Hi, thank you for the answer. I was thinking about internal usb2 connector. And it seems like there is none on the motherboard itself.
Tags (1)
Message 6 of 9
Message 6 of 9
@MrErnest
Your MB has an internal pin-connector for USB 2.0. The one which connects to the outer USB 2.0 Ports in the back. You could get a internal USB  signal for the power commander pro in this way.
cheers, daddle
MrErnest
Message 7 of 9
Message 7 of 9
Daddle, I would bee really happy if you could guide me to where it is on the motherboard? It would bee so cool to use the commander pro on the computer, many thanks in advance for help 🙂
Message 8 of 9
Message 8 of 9
@MrErnest
No, no Thanks in advance, because I can not do this.
If the backwards USB Port s´are soldered directly onto the Mainboard, you could make use of  the front USB 3.0  ports, which are connected by cable with the MB. Just follow this cable, and you will find the pinhead connectors.
Tags (1)
MrErnest
Message 9 of 9
Message 9 of 9
Im not able to find the internal USB 2 connector. But thanks for trying
8 REPLIES 8
