Keyboard back light not functioning correctly
4 REPLIES 4
EL_HoBo
Message 1 of 5
Message 1 of 5
My x6807 has developed an issue with the keyboard no longer lighting up. it went through a period of not starting up then going into default light mode but now will not light up at all. i have re installed the control center but that has not helped. if i try to use the control center to turn it on it just shuts down the control center. any help/advice will be much appreciated.
4 REPLIES 4
Gehringer
Retired
Message 2 of 5
Message 2 of 5
Hi @EL_HoBo ,
can you please provide the MSN number of your unit?
Also, have you tried any other troubleshooting in addition to reinstalling control center?
Regards,
Gehringer
EL_HoBo
Message 3 of 5
Message 3 of 5
Hi it is 30026173 i check for up to date drivers and even tried a factory reset but still have the same problem.
Gehringer
Retired
Message 4 of 5
Message 4 of 5
Hi @EL_HoBo ,
is your unit still in warranty?
Regards,
Gehringer
EL_HoBo
Message 5 of 5
Message 5 of 5
It is thankfully. I'm talking to medion it's soundlng like will be sending to be looked at
4 REPLIES 4
