am 12.02.2021 09:07
am 12.02.2021 09:07
Hello! I have an erazer P6661 MD99747 (MSN 30020121) laptop and I would like to install a 240gb m2 sata 2280, but when I connect it the laptop doesn't recognize it. Could it be a BIOS problem?
am 20.02.2021 08:05
am 20.02.2021 08:05
Hi! Sorry for the delay in responding. I have followed all the steps, but the SSD does not appear. Here I show you some screenshots.
am 20.02.2021 13:09
am 20.02.2021 13:09
Your pictures will be seen only after approval by a Mod.
Your PC following your given MSN 30020121 was delivered with a Toshiba SSHD TOSH 1TB SATA . Other Models P6661 were delivered wit a 128 GB Phison M2 SATA SSD plus a 1 TB HDD.
So it could be your M2 Slot is not fully electrically connected or implemented; simple dysfunctional.
We had this sort of problem with other PCs already.
You should ask a Mod, may be @Andi, if this could be the case with your Pegatron board as well. (Auch abhängig von den Bildern, was die aussagen!)
Bye, daddle
22.02.2021 06:55 - bearbeitet 22.02.2021 08:06
@soje schrieb:
Is your HDD disconnected when you took this foto?
Is your HDD listed here in this screen mask, if connected?
What happens if you press Return for the highlighted SATA mode?
If you swap to the other shown mode (is it Intel RST
If you swap to the other shown mode (is it Intel RST Premium With Intel Optane System Acceleration?)
Which options show?
Which options show?
