19.02.2021 17:58 - edited 19.02.2021 18:08
Just received this laptop today, is got great performance , but i think is running very hot and noisy , managed to create custom fan profile , and when i playing BFV , I Can see temps around 90c , any further tip ? or it is just the cooling design crap ?
20.02.2021 07:36 - edited 20.02.2021 07:39
Hi @gbakas , welcome to the forum
To solve the overheat problem on my laptop (different model) I use a FPS limit under nVidia control panel. As result from +90°C now it works at 60-84°C without loose of performance or any kind of stuttering.
I also added a cooling pat which overall drops about 5°C
Hope that helps.
Cheers
Subject | Author | Posted | |
07.01.2024 20:36 | |||
06.02.2025 17:41 | |||
12.02.2024 20:56 | |||
20.07.2024 08:50 |
