Erazer crawler e30e extra ram reference ?
5 REPLIES 5
Cemdesuka
Message 1 of 6
Message 1 of 6
Hello everyone 😀
I just bought the erazer crawler e30e with the I5-12450H and the rtx 2050.
It has 8go of DDR4 3200 MHz ram and I would like to add more ram, so i'm looking for the exact reference of the ram so I can order it now before it gets delivered.
Someone told me the exact reference is : M471AK43DB1-CWE from Samsung but I wanted to be sure before buying it so I can have the exact clock frequency.
On the website of Crucial they sell this reference that is to them compatible with my laptop :
Crucial 8GB DDR4-3200 SODIMM // CT8G4SFRA32A
so if anyone can help me, I'll be grateful,
Have a nice day
1 ACCEPTED SOLUTION
Message 6 of 6
Message 6 of 6
Hi @Cemdesuka
yes, it`s the same MSN Number 40081754
Bye Fishtown
5 REPLIES 5
RAZZ
Message 2 of 6
Message 2 of 6
dear @Cemdesuka
Sorry for the late reply, is this matter solved or do you still require assistance?
If you can supply the MSN number of your unit we can look into your request.
Thanks
Cemdesuka
Message 3 of 6
Message 3 of 6
Hello,
It has indeed been solved, I bought the Crucial RAM and it worked just fine.
Now I would like to know the exact reference for a possible battery replacement
Thank you
Message 4 of 6
Message 4 of 6
Hello @Cemdesuka ,
you can inquire about the battery in the Medion shop
https://www.medion.com/medionserviceshop/de/p/akku-akku-4-zellen-54wh-40081754
or order it from China (risk!).
https://www.akkubuy.de/akku-clevo/clevo-medion-erazer-deputy-p60i-np50rnd--akku.htm
bye Fishtown
Cemdesuka
Message 5 of 6
Message 5 of 6
Hello @Fishtown
Thank you for your quick response,
So the Erazer crawler e30e and the MEDION ERAZER DEPUTY P60I share the same battery ? That's interresting but thank you again for the two possibilities that you have sent.
Message 6 of 6
Message 6 of 6
Hi @Cemdesuka
Bye Fishtown
5 REPLIES 5
