24.11.2024 14:23 - edited 24.11.2024 16:15
I'm trying to change the ram speed on my Erazer P15811 laptop, I've found no option through the basic BIOS or no advanced section to alter anything or nothing in control center
MSN : 30028178
Not sure if there's a work around or if i can update bios to be able to
Im trying to lower speed from 3200mhz to 2666mhz which I thought would happen automatically
Any help would be really appreciated, many thanks
BIOS Version/Date : INSYDE corp. 1.07.13RME1_00011, 17/09/2019
SMBIOS Version : 3.0
Embedded Controller Version : 7.01
BIOS Mode : UEFI
BaseBoard Manufacturer : MEDION
BaseBoard Product : NH55RCQM1
BaseBoard Version : 1.0
on 24.11.2024 16:20
on 24.11.2024 16:20
@Major_ToM not sure if you could help in any way but anything would be really appreciated
Many thanks
on 24.11.2024 18:35
on 24.11.2024 18:35
hello @Greentree and welcome
The built-in RAM memory only has 2666MHz see here:
https://www.medion.com/gb/service/product-detail/30028178
https://www.medion.com/medionserviceshop/en/p/housing-nb-p15811-erazer-md61748-uk-ref-30034726
Look in the BIOS, but I don't think you can set it there.
Excerpt from the user manual (NH55RCQ):
bye Fishtown
on 24.11.2024 18:51
on 24.11.2024 18:51
Yeah I dont think theres any way to change it in the current BIOS
It's just annoying because when I put in 1 2666mhz and 1 3200mhz it is able to run both at the lower speed however no way to manually set it
Do you know if there's a possible updated BIOS I can't see any in the driver package but you never know
Thanks a lot for the response @Fishtown !
