Erazer Major X20 Bios update?
15 REPLIES 15
BlindWarrior
Message 1 of 16
Message 1 of 16
Hello,
I own an Erazer Major X20 with the following serial number:
GM6PX7X2230703757
The machine is currently running Bios version:
BIOS Version: N.1.09MED06             Build Date and Time: 09/26/2023 10:59:58
Since this bios is from 2023 I was wondering if there is a newer bios version available for this machine? Could somebody from the medion/erazer support staff check this for me?
Everything works fine so far, but I like to stay up to date with my bios versions.
Thank you very much!
p.s.
I checked the driver page for this laptop and there is no bios version posted there. Also, the bios I installed previously (see the number above) is not listed there but I got it somewhere on this forum.
15 REPLIES 15
RAZZ
Message 2 of 16
Message 2 of 16
Hi @BlindWarrior
DO you have the MSN number? 8 digits long found on the device to correctly identify so we can check if there is an updated BIOS version for your exact device.
thanks
BlindWarrior
Message 3 of 16
Message 3 of 16
Hi Razz,
Thank you for helping me. I wish I can provide the number but I can't find it on my system.
I would like to say that I am blind but the person who helped me can't find any msn number.
She made pictures of the laptop though, Can I send them to you so you could have a look yourself. Or is there another way to find it in the system itself?
BlindWarrior
Message 4 of 16
Message 4 of 16
Hi @RAZZ I forgot to mention you in my previous post. Thank you for your help.
Message 5 of 16
Message 5 of 16
Hello @BlindWarrior  and welcome!
You can insert photos when you write a post and click on the camera symbol (top bar) to insert the images.
You have several options for finding your MSN number.
Check the bottom of the device or the packaging.
Use the Medion Services app
https://www.medion.com/gb/service/service-app
or press the Windows key + R and type "msinfo32". Look under "system SKU".
bye Fishtown
BlindWarrior
Message 6 of 16
Message 6 of 16
Hello @Fishtown and @RAZZ ,
In msinfo32 under system sku is the following number:
ML-210015 40084496
Is this something you can use to help me further?
Best regards,
BlindWarriorSven
RAZZ
Message 7 of 16
Message 7 of 16
hi @BlindWarrior
Out of interest was this a sample unit pre sales release, as the MSN 40084496 shows this as product description:- NB TFG Sample GM6PX7X Seeding Unit NL,
If you able to supply images of all the stickers on the underside this would be helpful so a correct BIOS can be looked into.
thanks
BlindWarrior
Message 8 of 16
Message 8 of 16
Hello @RAZZ , I got this laptop as part of a sponsorship with Erazer. So it might be perfectly possible that this one is not from a retailer or such. I hope it worked to insert the pictures in this message. I can't see them myself due to accessibility limitations.bovenkant laptop.jpgopen en met lichtjes totaal plaatje .jpgopen met buroblad met de tijd .jpgopen zonder lichtjes .jpgvoorkant open met lichtjes .jpgzijkant 1 .jpgzijkant 2 met 2 poortjes .jpg
BlindWarrior
Message 9 of 16
Message 9 of 16
Hi @RAZZ , I think that not all images were uploaded due to size limitations. I'll try again.onderkant_compressed.jpg
RAZZ
Message 10 of 16
Message 10 of 16
hi @BlindWarrior
Thanks for the reply, the images will need approval before they show on the forum.
cheers
15 REPLIES 15
