Erazer Deputy P60 MD62590 Ram Upgrade
5 REPLIES 5
VOIVI
Message 1 of 6
Message 1 of 6
Hello,
I'm trying to source replacement upgrade RAM for my Deputy P60, however the crucial scanner doesn't seem to work with this laptop and the System option only states 16GB ram, without providing any detail of the exact type of Ram that I need.
Can anyone tell me what ram is installed on my system please?
MSN 40086125
I've tried using the spare parts search facility at the Medion shop, but it cannot find my laptop using the MSN or the model number.
Tags (3)
5 REPLIES 5
Luke
Community Manager
Message 2 of 6
Message 2 of 6
Hello @VOIVI,
we are currently having problems accessing our internal database, but according to our shop page, this model can have a total of 32 GB RAM, i.e. a maximum of 2x 16 GB modules of the same type as the installed modules.
Hope this helps,
Luke
VOIVI
Message 3 of 6
Message 3 of 6
Thank you Luke. I've managed to identify the RAM modules as 2 x SK Hynix 8192 MB (DDR4-3200) - P/N: HMAG68EXNSA051N
I'm was a little shocked to see you state that 32GB is the max available RAM for this gaming laptop. I ran CPU-Z which suggested 2 x 64GB was the max.
Can you confirm which is correct please?
Unfortunately I can't seem to upload my screengrab for some reason.
Message 4 of 6
Message 4 of 6
hello @VOIVI and welcome
You can now find your MSN number in the shop.
https://www.medion.com/de/service/product-detail/40086125
information about your ram:
DDR4 SO-DIMM (PC4-25600/ 3200 MHz)
service manual (barebone clevo NP50RND1):https://drive.google.com/file/d/1s-U1G4ljs1NjCCrXnDQ3KBwlUpKhqMgT/view?usp=sharing
bye Fishtown
VOIVI
Message 5 of 6
Message 5 of 6
VOIVI
Message 6 of 6
Message 6 of 6
Apologies Luke, I just cross posted.
Thankyou for the manual. The manual itself does state the following too.
Dual Channel DDR4
Two 260 Pin SO-DIMM Sockets
Supporting up to 3200MHz DDR4 Memory
Memory Expandable up to 64GB
Compatible with 8GB,16GB or 32GB Modules
(The real memory operating frequency depends
Many thanks
5 REPLIES 5
