Erazer Beast x25 Random Blue Screens and Reboots
2 REPLIES 2
ElCruz
Message 1 of 3
Message 1 of 3
Hello everybody,
I just bought a new laptop which was the Beast x25 and after only 20 days of usage, I got random blue screens with the error : KERNEL_SECURITY_CHECK_FAILURE when I was working on different projects. And most of the times when I leave alone the laptop for about 10 minutes when I try to use it again, it reboots with everything closed. It's starting to get really annoying because I need to re-open everything again.
I first though it was because the laptop needed an update but everything was up to date.
Anyone got any clues about those errors ? It would help a lot.
Thanks a lot,
ElCruz
2 REPLIES 2
Gehringer
Retired
Message 2 of 3
Message 2 of 3
Hi @ElCruz ,
can you please provide the MSN number of your unit?
Also, please check this page here and try the troubleshooting mentioned.
We advise you not to download and install any software from this website nor click on any of the links, since we can't guarantee they are not malicious.
Regards,
Gehringer
Message 3 of 3
Message 3 of 3
Hi @ElCruz ,
maybe you could report us,if your problems with the machine are still present,or did you find a solution?
Cheers
2 REPLIES 2
