on 25.01.2021 18:56
on 25.01.2021 18:56
Evening all,
I have an erarer P6605, my daughter decided to pull the screen completely down breaking the hinges, there seem to have sheared from the support.
I've contacted Medion who say the hinges are no longer availbe, I was wondering if the same hinges were used in different models as some come up on ebay from time to time?
Any help would be greatly appreciated.
Cheers
Paul
25.01.2021 22:13 - edited 25.01.2021 22:22
Hi @wainwright2 and welcome,
you have a P6605 (Clevo N857EJ1)
Service manual with spare parts list:
N850EJ1_SM (20180502) .zip
Look here at the spare parts,
A. Part lists / Page A-9 LCD (N857EJ1)
Number 6 LCD Hinge L (S GCC + S50C (MP) N850HC
Number 16 LCD Hinge R (SGCC + S50C (MP) N850HC
Now you go to the Clevo Shop and make an inquiry there.
edit: https://clevo-computer.com/en/contact-form
good luck bye Fishtown
on 25.01.2021 22:48
on 25.01.2021 22:48
Thank you so muc, I'm going to email them and hopefully that will end a 3 month saga.
Really appreciate you help
Regards
Paul
