Eraser Beast x40 how do I remove the back cover
4 REPLIES 4
tipsythomas
Message 1 of 5
Message 1 of 5
The model is the i9 14900hx with 4090.
I've removed the 12 screws & the 2 rear ones sides of the water cooling fitting.
The cover will lift up at the front of the laptop but not the rear, seems to be connected to the fan exhausts as they flex with the cover when lifting.
I can't find any clues in the manual or forums & YouTube vids
1 ACCEPTED SOLUTION
tipsythomas
Message 5 of 5
Message 5 of 5
I've just figured it out. 💪😎👍🎊🎉
Half of the fan outlet's and the rear socket wall is all attached to the rear plate, a firm but gentle lift/pull is needed.
Thanks for the help & responses guys.
4 REPLIES 4
RAZZ
Message 2 of 5
Message 2 of 5
dear @tipsythomas
It seems that you have done everything correctly and those are the correct screws, all I can think is that it has over heated and the plastic has melted onto the fan.
please let us know how you have got on.
Thanks
tipsythomas
Message 3 of 5
Message 3 of 5
I'll have another look at it over the weekend, it shouldn't have melted tho as it's ment to be bran new! It had all the protection still on & since I'm concerned about the Intel CPU problems I've kept it on silent/office mode.
Message 4 of 5
Message 4 of 5
Hi @tipsythomas
The base cover should be easy to remove, see here from 11:03
https://www.youtube.com/watch?v=lerC7jRtfZ4
bye Fishtown
tipsythomas
Message 5 of 5
Message 5 of 5
4 REPLIES 4
