Eraser Beast X25 Bios 1.26MED11
26 REPLIES 26
Pete748
Message 1 of 27
Message 1 of 27
Hey Folks,
I've just had windows push a BIOS (1.26MED11) update to my laptop.
Does anyone have the patch notes?
Thank you
26 REPLIES 26
slackbladder
Message 21 of 27
Message 21 of 27
I temporarily fixed the Control Center by installing what was on the D drive (which is a pain to get into because it is behind a BitLocker) so right now I have Control Center service 3.1.4.0 but I do not have all the functions as before. So what should I do now? Uninstall CC service, use the defaulttool and then install 3.33.21.0?
Schummi
Specialist
Message 22 of 27
Message 22 of 27
Hi @slackbladder
if you are still missing some options in your Control Center you can also reinstall the older Control Center service version but at least you must uninstall the CC service once, execute defaulttool.exe, reboot, install ( any kind of) Control Center service again.
Bitlocker encryption is enabled by default: https://docs.microsoft.com/en-us/windows-hardware/design/device-experiences/oem-bitlocker
slackbladder
Message 23 of 27
Message 23 of 27
Hi
Thanks for the explanation. It worked and I have all the options back. Thank you.
agent-orangeCH
Message 24 of 27
Message 24 of 27
@Schummi
Do you know if it possible to do a bios recovery with an USB stick? According to this page https://www.biosflash.com/bios-update-fehler.htm I can put a bios on a stick and boot with "<Strg><Pos1>" to start the bios flash process.
Kaveha1987
Message 25 of 27
Message 25 of 27
Hi all,
In New here but just want to say, after te new bios update my laptop went silent  ( no fans) while updating te new bios then something burned.. inside.. still not knowing what happened but now i read this thread i know why.
Laptop is back to webshop  for repair.. but still no news.. dont think i cant be repaired...
Is there already a Fix i some sort?..
If u get mine back repaired or a new one... I dont wanna make the same misstake by update with the same bios?.. and get pack of performance?
Revo
Message 26 of 27
Message 26 of 27
The files download from
1. Install DMI-Patch from here: https://www.medion.com/at/service/product-detail/30032959
2. Follow the FAQ: https://community.medion.com/t5/FAQs/How-do-I-get-back-missing-settings-options-in-Control-Center/ta...
triggers alarm from Bitdefender after i ran the program and was not allowed to run. Any idea why they both triggers antivirus alarm?
ThaMadden
Message 27 of 27
Message 27 of 27
Maybe silly question, but anybody else experiencing USB issues? Since the erroneous BIOS update i seem to get errors when copying large amounts of data (tens of gigabytes as one data stream) to external flash drives. After some time while copying i get the error that the device is not ready.
This hasn't happened before, but I am not sure if this could be tight to that faulty update.
Anybody else with similarit issues suddenly?
26 REPLIES 26
