ERAZER X7847 keyboard
7 REPLIES 7
martymcfly
Message 1 of 8
Message 1 of 8
I am trying to find a keyboard for this as the W no longer works.
How do i take the keyboard out of the laptop?
I cannot see how i can get a blade in the top like any other laptop.
There is a laptop screw underneath though.
Anyone know how?
Mine is the version that is backlit etc
1 ACCEPTED SOLUTION
martymcfly
Message 5 of 8
Message 5 of 8
I have managed to remove the keyboard. I slid a pry tool under the top left corner of the keyboard.
Prior to this I removed the two screws under the laptop to remove the keyboard.
Many thanks.
7 REPLIES 7
martymcfly
Message 2 of 8
Message 2 of 8
Anyone?
sweetpoison
Message 3 of 8
Message 3 of 8
Welcome to the forum.
For removing the keyboard: possible answer is already posted in a similar thread (search function usually helps)
Anyway:
First check around keyboard for holder marks like the one in pic (above ESC)
See on this video how the keyboard can be removed. https://www.youtube.com/watch?v=joLnSK9N-uU
The lack of marks means different holding system and in that case ignore everything I said.
Other than that you might consider the warranty before removing the laptop's covers or keyboard.
Cheers.
martymcfly
Message 4 of 8
Message 4 of 8
Thanks for the reply.
There is no keyboard holder points to access hence my post.
 There is no warranty on this as its over 3 years old.
As for the video that is not the model I have and not relevant sadly.
martymcfly
Message 5 of 8
Message 5 of 8
Many thanks.
martymcfly
Message 6 of 8
Message 6 of 8
Just by luck I managed to find a new replacement keyboard.
It was a Chinese seller on Ebay.
I have a UK machine and their keyboard was a USA model.
It took me over an our to get it spot on but it's finally in and working fine. The LED works but not 100% like the OEM.
That being said for £38 UK pounds i am very happy.
Message 7 of 8
Message 7 of 8
Hi @martymcfly ,
for the next time, Original keyboard from X7847 ( Clevo P 670Rp6-M):
https://clevo-computer.com/de/ersatzteile/clevo/tastaturen/p65x-p67x/?p=2
bye Fishtown
martymcfly
Message 8 of 8
Message 8 of 8
Hi @Fishtown  and thank you for the reply.
I needed a UK keyboard or at the very least US.
I now have it fully working. I imagine they are both the same as most are made in China.
Item came from China in less than a week too.
£38 Uk pounds to boot!
7 REPLIES 7
