am 01.12.2020 17:06
am 01.12.2020 17:06
Hi, I recently bought a new computer. Specifically the ERAZER Engineer X10 (MD 34944) NL. And the fans inside are the polaris inwin fans which are rgb. Im wondering if there is any way to change the colors of the fans since the cpu fan is a slightly different color compared to the other two.
am 01.12.2020 17:39
am 01.12.2020 17:39
Hi @LuqyAF and welcome to the FORUM!
You may find third party softwares that controls and synchronize all the LED lights, including the Fans.
Medion can't take any responsibility for the use of these softwares.
Please take a look at this topic here where an example of software is given by an user
It is in German, but you can always rely on a good browse translator.
Regards,
Gehringer
am 01.12.2020 20:36
am 01.12.2020 20:36
Hi @LuqyAF and welcome,
translate Post2:
bye Fishtown
am 05.12.2020 12:54
am 05.12.2020 12:54
Hi again, My motherboard isn't compatible with msi mystic aura because it isnt a mystic aura motherboard. I have one of medions oem motherboards which dont have an software for rgb if im not mistaken.
am 12.12.2022 22:24
am 12.12.2022 22:24
Bump. Still haven't found a solution to change my rgb.
am 13.12.2022 22:09
am 13.12.2022 22:09
hello @LuqyAF
I see now that you have a B460H6-EM board. there it is definitely not possible to change the colors.
The ECS B460H6-EM board used has no RGB control.
bye Fishtown
am 05.08.2024 01:04
am 05.08.2024 01:04
Hiya, I have only found a way to change one of the lights. If you go into ur wondows searchbar and type 'RGBLightCentre' it should come up. You can only change the middle light with this. Hope that helped
(if anyone finds out how to change the other 2, please tell me T-T)
