le 01.04.2020 11:26
le 01.04.2020 11:26
Just bought it and am at the point of installing software - Office 365, VLC and stuff and fan is constantly at 80 % or more, which is VERY loud. What to do ? I cant even imagine what will happen when i try an actual game.
le 01.04.2020 16:17
le 01.04.2020 16:17
Hi @mperus and welcome to the forum.
Can you please tell me what is the MSN number of your NB?
It is an 8 digits number printed in the label underneath it (usually starting by 300 or 500).
Also, does the fan start to go loud from the start of your PC or only when you start downloading software?
Regards,
Gehringer
le 01.04.2020 18:19
le 01.04.2020 18:19
hello,
MSN is 30027187, and fan starts going crazy whenever I install something or play and game. When computer starts it's ok.
le 02.04.2020 10:18
le 02.04.2020 10:18
Hi @mperus ,
have you been monitoring the internal temperature of your NB? If so, how is it?
Also, can you check that these softwares you are running are not set to be run in the high performance mode or that this is not the default mode set for running programs?
Regards,
Gehringer
le 03.04.2020 08:51
le 03.04.2020 08:51
Everything on default, NB on balanced, when firefox is opened right now with 4 tabs it 45 °C. When installing something there is an instant jump to 70.
le 03.04.2020 09:44
le 03.04.2020 09:44
Hi @mperus ,
please check that you have the latest Windows and Drivers updates installed.
After that, you can download and run our self diagnose app (find it here) to check your NB for any faults.
If nothing comes up from that, can you please tell me which is the BIOS version you are currently on?
Regards,
Gehringer
le 09.04.2020 06:39
le 09.04.2020 06:39
no, didn't fix anything. i tried every possible driver combination to improve anything, laptop is still loud as hell.
BIOSVersion
{"MEDION - 0", "1.07.06RME4_00005", "INSYDE Corp. - 58042004"}
le 09.04.2020 13:17
le 09.04.2020 15:31
le 11.04.2020 07:14
le 11.04.2020 07:14
made a screenshot, atom btw. is a text editor - that should be something a gaming laptop is able to handle.
Subject | Author | Posted | |
08.12.2024 00:21 | |||
19.10.2024 09:38 | |||
14.06.2019 03:07 | |||
08.01.2021 21:01 |
