Abonormal high CPU temperature during gaming
1 ANTWOORD 1
Ugo
Bericht 1 van 2
1.001 Weergaven
Bericht 1 van 2
1.001 Weergaven
Hello,
during gaming (GTA V), while the GPU runs at about 65°C, the CPU goes up to 80°C.
I'm sure the app picks up correctly the nVidia GPU and not the Radeon GPU (the one integrated in the CPU).
This is not normal IMHO. I'ts too hot and I fear the CPU will be damaged.
How can I correct the problem?
Everything else with the PC runs fine. I've plenty of space around the notebook.
My configuration is as follows. Thanks for your ideas.
Tags (2)
1 ANTWOORD 1
Bericht 2 van 2
998 Weergaven
Bericht 2 van 2
998 Weergaven
@Ugo
65° degrees C for the graphic card and 80° for the CPU ist absolutly correct and safe. No reason to worry.
cheers, daddle
1 ANTWOORD 1
