Help please! Bios Update "Beast X20-MD 62207"
9 ANTWORTEN 9
Kandizhka
Nachricht 1 von 10
1.793 Aufrufe
Nachricht 1 von 10
1.793 Aufrufe
Hello. My laptop is broken and I really need BIOS firmware for it, please help!
Model: Medion erazer beast x20 md6220 (MSN 30031378)
Specs: Intel core i7-10870H, Nvidia rtx 3070
Most likely version N.1.08MED02 will suit me
Also if you have firmware for EC it would be very cool
Nachricht 6 von 10
1.672 Aufrufe
Nachricht 6 von 10
1.672 Aufrufe
Hello @Kandizhka.
I have just sent you a private message.
Greetings - Andi
9 ANTWORTEN 9
Nachricht 2 von 10
1.744 Aufrufe
Nachricht 2 von 10
1.744 Aufrufe
Hello @Kandizhka and welcome
tell us a little more, what exactly is defective that requires a bios update?
bye Fishtown
Kandizhka
Nachricht 3 von 10
1.736 Aufrufe
Nachricht 3 von 10
1.736 Aufrufe
Hello! Thanks for the answer.        The laptop does not display an image either on the built-in matrix or on an external monitor, while the cooling fans rotate, the power indicator lights up, and when you press the Caps Lock key there is also a reaction (the LED lights up), sometimes the display backlight lights up, but nothing more. The laptop will continue to operate in this mode until you turn it off using the power buttons.
Known working RAM is installed.
Nachricht 4 von 10
1.725 Aufrufe
Nachricht 4 von 10
1.725 Aufrufe
Hi @Kandizhka
If you haven't changed any components beforehand, the graphics card/chip will probably be the problem.
A firmware update is of no use to you if you can't see anything.
Try to get into the BIOS using F2. Maybe this still works because you also have integrated Intel UHD graphics in the CPU.
Otherwise you will probably need a new motherboard (MSN 40079215/ 1224.-€)
How old is the device, is it still under warranty?
I would send the device to Medion for repairs/cost estimates.
bye Fishtown
Kandizhka
Nachricht 5 von 10
1.714 Aufrufe
Nachricht 5 von 10
1.714 Aufrufe
I didn’t change the components, once when updating the BIOS the battery did not have enough charge and after that it behaved like this. The warranty has long expired. Perhaps you can still share the BIOS firmware and EC firmware? I would like to try this option
Nachricht 6 von 10
1.673 Aufrufe
Nachricht 6 von 10
1.673 Aufrufe
Hello @Kandizhka.
Greetings - Andi
simrug
Nachricht 7 von 10
630 Aufrufe
Nachricht 7 von 10
630 Aufrufe
x20 md 62257
Hello, I need the bios software for this device. Can you help me?
Sincerely regards
Halit
Nachricht 8 von 10
596 Aufrufe
Nachricht 8 von 10
596 Aufrufe
Hallo @simrug und herzlich willkommen in der Community.
Bitte teile uns einmal die achtstellige Artikelnummer (MSN) deines Laptops mit.
Warum benötigst du ein BIOS Update?
Welche BIOS Version ist aktuell installiert?
simrug
Nachricht 9 von 10
591 Aufrufe
Nachricht 9 von 10
591 Aufrufe
Ich wünsche Ihnen einen schönen Tag.
Zunächst einmal herzlichen Dank für Ihre Nachricht.
Ich habe den Leptop aus zweiter Hand gekauft, das kann ich beweisen.
Der Vorbesitzer hat ein Bios-Passwort gesetzt und es vergessen.
Ich denke, ich muss den Bios-Chip neu programmieren.
Gerätenummer MSN 30031761
Freundlichen Grüssen
simrug
Nachricht 10 von 10
525 Aufrufe
Nachricht 10 von 10
525 Aufrufe
I hope you have a wonderful day.
First of all, thank you very much for your message.
I bought the Leptop second hand, I can prove it.
The previous owner has a Bios-Password and it is being erased.
I think I need to make the bios chip new programmer.
Device MSN 30031761
9 ANTWORTEN 9
