Fans speed on a Erazer Deputy P10
20 ANTWORTEN 20
and76
Nachricht 1 von 21
13.901 Aufrufe
Nachricht 1 von 21
13.901 Aufrufe
Hello guys.
I have a Medion Erazer Deputy P10 laptop, MD63665. The issue is that the cpu fan automatically raises its frequency, and noise, without gaming or doing tasks that require cpu overload. With hotkeys I manage to decrease its frequency, but it increases again in a few minutes. I reinstalled Windows 11 to version 22H2, but this problem continues. I do not think it is a hardware problem, because with the battery in Saving mode this problem does not appear.
Control Center always shows me the speed of the CPU fans above 6000 RPM, but it doesn't show the speed of the GPU fans.
I would appreciate help.
Andres (Cuba).
20 ANTWORTEN 20
and76
Nachricht 11 von 21
5.630 Aufrufe
Nachricht 11 von 21
5.630 Aufrufe
Dear Burki.
I didn't modify the BIOS default values, should I?
All the best.
Burki48
Nachricht 12 von 21
5.629 Aufrufe
Nachricht 12 von 21
5.629 Aufrufe
Hello @and76,
you can only load die BIOS Defaults, but you can´t modifiy it.
Greetings
Burki
and76
Nachricht 13 von 21
5.628 Aufrufe
Nachricht 13 von 21
5.628 Aufrufe
Hi Burki.
All the best
Burki48
Nachricht 14 von 21
5.614 Aufrufe
Nachricht 14 von 21
5.614 Aufrufe
Hallo @and76,
don´t modify the BIOS defaults.
Greetings
Burki
and76
Nachricht 15 von 21
5.594 Aufrufe
Nachricht 15 von 21
5.594 Aufrufe
Dear Burki.
How and where can I get the last version of Control Center?
All the best.
And.
Mastermind
Nachricht 16 von 21
5.580 Aufrufe
Nachricht 16 von 21
5.580 Aufrufe
Hi @and76
here you find the current version of the Hotkey-Tool/Control Center of the MEDION ERAZER Deputy P10 notebook.
Cheers
Nachricht 17 von 21
5.572 Aufrufe
Nachricht 17 von 21
5.572 Aufrufe
@Major_ToM
Hi, just for information, your link ends on a 404 page. " The requested URL was not found on this server."
Mastermind
Nachricht 18 von 21
5.564 Aufrufe
Nachricht 18 von 21
5.564 Aufrufe
..then I have to admit,..I just programmed it to be working for and76.. :-D.pulled your leg
and76
Nachricht 19 von 21
5.556 Aufrufe
Nachricht 19 von 21
5.556 Aufrufe
Thank you both!
and76
Nachricht 20 von 21
12.356 Aufrufe
Nachricht 20 von 21
12.356 Aufrufe
Folks.
The whole problem was the fan of the GPU stuck, with dust... Solved everything with preventive maintenance, and change of thermal paste.
Thank you all.
20 ANTWORTEN 20
