swapping psu - hidden screws?
2 RÉPONSES 2
Geordio
Message 1 sur 3
878 Visites
Message 1 sur 3
878 Visites
Hi, I have an Akoya E32014 and want to stick in a GPU, so I'm going to upgrade the PSU too. I have removed the 4 screws on the back of the case but the PSU still seems to be fixed into the case somehow - it's not just sliding out. Is there a hidden screw somewhere that I'm missing? Is the psu meant to be swapped out from this model or have they fixed it in on purpose so it can't be removed? You can't take the other side of the case off to check. Any help gratefully received, thanks.
1 SOLUTION APPROUVÉE
Solutions acceptées
Message 2 sur 3
858 Visites
Message 2 sur 3
858 Visites
Hello @Geordio and welcome.
If I understand correctly, you have to push the locking bracket in to slide the power supply inward after removing the four screws on the back.
bye Fishtown
2 RÉPONSES 2
Message 2 sur 3
859 Visites
Message 2 sur 3
859 Visites
bye Fishtown
Geordio
Message 3 sur 3
855 Visites
Message 3 sur 3
855 Visites
thanks, yes, I found that already. Thanks for confirming though!
2 RÉPONSES 2
