swapping psu - hidden screws?
5 ANTWORTEN 5
Geordio
Nachricht 1 von 6
1.445 Aufrufe
Nachricht 1 von 6
1.445 Aufrufe
Hi, I have an Akoya E32014 and want to stick in a GPU, so I'm going to upgrade the PSU too. I have removed the 4 screws on the back of the case but the PSU still seems to be fixed into the case somehow - it's not just sliding out. Is there a hidden screw somewhere that I'm missing? Is the psu meant to be swapped out from this model or have they fixed it in on purpose so it can't be removed? You can't take the other side of the case off to check. Any help gratefully received, thanks.
Nachricht 2 von 6
1.425 Aufrufe
Nachricht 2 von 6
1.425 Aufrufe
Hello @Geordio and welcome.
If I understand correctly, you have to push the locking bracket in to slide the power supply inward after removing the four screws on the back.
bye Fishtown
5 ANTWORTEN 5
Nachricht 2 von 6
1.426 Aufrufe
Nachricht 2 von 6
1.426 Aufrufe
bye Fishtown
Geordio
Nachricht 3 von 6
1.422 Aufrufe
Nachricht 3 von 6
1.422 Aufrufe
thanks, yes, I found that already. Thanks for confirming though!
mitko
Nachricht 4 von 6
338 Aufrufe
Nachricht 4 von 6
338 Aufrufe
could you tell me can i upgrade the psu with 750 w corsair ,where to find that motherboard 24 to 14 pin adapter
Nachricht 5 von 6
332 Aufrufe
Nachricht 5 von 6
332 Aufrufe
Hello @mitko and welcome.
The E32014 computer has a B460 motherboard which has a 24-pin connector. What do you need a 14-pin connector for?
bye Fishtown
mitko
Nachricht 6 von 6
305 Aufrufe
Nachricht 6 von 6
305 Aufrufe
Motherboard is H110H4-EM2 wih 14 pin atx plug , 3 pins are empty,i already ordered 24 to 14 pin atx adapter for ibm/lenovo ,will be like diy till i check it with voltmeter.I need to upgrade the psu with cx750m ,i hooked 1080 sc and 6 hdd,  i wil buy new case for all that stuff
5 ANTWORTEN 5
