Wifi card for P20 MD35361
4 RÉPONSES 4
diabolofrais
Message 1 sur 5
1 119 Visites
Message 1 sur 5
1 119 Visites
Hi there !
I have recently purchased a P20 MD35361.
I tried to install an intel based PCIe wifi card, namely Aliexpress FENVI AXE3000
Unfortunately, the card is not seen in windows despite PROSET driver install.
There are several posts discussing this issue, could not find a working fix.
Anyone faced (and solved 🙂)  this issue ?
Anyone could advice a different wifi card model working on this Medion ?
It could be Either PCIe or Wifi M.2 port ?
Many thanks in advance for your help !
Pierre
4 RÉPONSES 4
Message 2 sur 5
1 057 Visites
Message 2 sur 5
1 057 Visites
Hi @diabolofrais ,
I´m not sure, if you´ve already fixed your problem, but I´d suggest to use one of these tine M.2 Wifi-Card with E-Key 2230 (CNVI) like the INtel Intel AX201.NGWG which supports IEEE 802.11 a/b/g/n/ac/ax protocols.
Cheers
diabolofrais
Message 3 sur 5
1 013 Visites
Message 3 sur 5
1 013 Visites
Many thanks Tom for your answer,
I did find a solution, by simply doing what has been depicted in a previous post 😁Erazer Recon P20 MD35361 / Emplacement 2e SSD - MEDION Community
Indeed, I ordered and install this card which proved to be compatible with the mentioned medion :
https://www.amazon.fr/gp/product/B0B45Z4ZFK/ref=ppx_yo_dt_b_asin_image_o01_s01?ie=UTF8&psc=1
Thanks again for your help.
Pierre
plutissimo
Message 4 sur 5
123 Visites
Message 4 sur 5
123 Visites
Hi @Major_ToM,
I am looking to install a Wifi & Bluetooth M.2 card (E-key) as you suggest in your post above.
Is there any recommendation as to what antennas to get and how to install them?
Thanks, plutissimo
Message 5 sur 5
117 Visites
Message 5 sur 5
117 Visites
Hello @plutissimo , you can use any commercially available one that corresponds to the settings of the interface slot, as described in the article.
It is important that the antennas are outside.
If you prefer original Medion built-in parts, you can also find the antenna and WiFi module for your Recon P20 MD35348 here:
https://www.medion.com/medionserviceshop/en/p/housing-medion-akoya-p-63019-md35314-de-10024751
A b660h7-m20 board is also installed there. Unfortunately your computer is not listed.
bye Fishtown
4 RÉPONSES 4
