Upgrade graphics card
5 REPLIES 5
GamefreaQnl
Message 1 of 6
Message 1 of 6
Is it possible to upgrade my GTX 1060 from my Medion Erazer x67037 to an RTX 2080 of the new RTX 3070 when it comes out?
or is my wattage from my power supply to low? because i cant find the power supply how much it delivers
5 REPLIES 5
Message 2 of 6
Message 2 of 6
@GamefreaQnl
Your PC has a 450W Fortron PSU  ( Power supply Fortron FSP450-50AMDN) just give me your  MSN- number .
But  ìt also needs an additional 6+2 Pin power supply plug to be connected to your Graphic card  depending  which graphic card you will prefer. I do not know with which plugs the Fortron is equipped.
Cheers, daddle
GamefreaQnl
Message 3 of 6
Message 3 of 6
Dear Daddle,
The MSN number from my pc is: 10022384
Do you now which one fits in my current pc's with the pins? (speaking of the RTX cards)
Message 4 of 6
Message 4 of 6
@GamefreaQnl
Some more details
Input
180 - 264 Vrms (AC)
: 47 - 63 Hz
: 3,5 Amp (maximum) at 200-240 Vrms/ 50 Hz
Output (maximum)
: +3.3V: 24/13.6A
: +5V: 8/15A
: +12V: 36A
: -12V: 0.3A
: +5Vsb: 3A
Sorry, I cant tell you which card will fit in the case . You should measure it.
GamefreaQnl
Message 5 of 6
Message 5 of 6
Dear Daddle,
Do you know how much wattage my current 1060 is using?
kind regards
Message 6 of 6
Message 6 of 6
@GamefreaQnl
No, this you can explore by yourself looking at advertisments or checking on the Nvidia homepage.
bye, daddle
5 REPLIES 5
