Screen freezes when trying to access boot menu
22 REPLIES 22
Planeman653
Message 1 of 23
Message 1 of 23
I'm trying to upgrade my pc from windows 32 to 64 bit. I want to boot a usb so i can install it but when i try to access the boot menu to change the boot priority, the screen just freezes.
Any help is appreciated!
Specs:
Akoya E4360 D
processor
Intel® Core™ i3-530 Processor
motherboard
MS-7616 with 4 ddr3 supporting 16gb 1333/1066 mhz ram, pcie x16 & x1, 6 SATA II
memory
4GB
drives
1TB & DVD Writer
power supply
350w
ports
VGA, 6 rear and 2 front usb 2.0, 2 front audio(speaker and mic), DVI, HDMI, Keyboard And Mouse Ports, Ethernet
graphics
GeForce GT330
22 REPLIES 22
Planeman653
Message 21 of 23
Message 21 of 23
Hi daddle,
What i meant by that was that the boot menu was re ordered because i shorted the JBAT1 Pins. Since the hard drive was plugged in, the system attempted to boot from the hard drive(Which was empty) so i had to unplug it to boot into windows. This probably means that i can alter what drive(SSD or HDD) is first in the boot priority. Hope this helps!
Message 22 of 23
Message 22 of 23
@Planeman653
Thanks, thats more explicit and understandable. It's a sort of setting defaults, then of course the HDD at those days was  the first bootable device, except an optional Floppy in the  floppy drive.
I have no further idea.
May be flashing the latest Bios (which presumably has to be done in Windows 7) could help. You can use a WIn 7 bootstick, or a Dos Version, if you have the flashing tools for Dos as well.
@Hartilein  Do you know somne ways to enter Bios on this with Win 10 upgraded  machine with legacy bios?
Hartilein
Advisor
Message 23 of 23
Message 23 of 23
Sorry!
With so many imponderables, unfortunately I can't give any helpful advice!
Best regards! Hartilein
22 REPLIES 22
