Radeon RX 550 no signal
6 ANTWORTEN 6
tl1000edu
Nachricht 1 von 7
20.467 Aufrufe
Nachricht 1 von 7
20.467 Aufrufe
Hi, I´ve already installed a brand new Power Color Radeon rx 550 4gbD5 in my PC and It doesn´t work. I´ve a "no signal" message on my display and I guess my OS (W10 64bit) cannot boot, because if I press the power button it turns off inmediately. Obviusly, I´m not able to see what´s happening, I don´t know if the bios works and w10 is unable to start or whatever...While the graphic card is is attached to the mother board the integrated hdmi doesn´t work too. If I remove the new graphyc card from the mother board it works normally.
My pc model is
Modell: PC MT 14
Typ: MED MT742G
Art.-NR.:  10015594  (probably this is the MSN)
MED S/N: 17987010020142
Mother Board: MS-7728 VER: 2.0 Bios version: 2.02.1205
Thanks for your help.
tl1000edu
Nachricht 6 von 7
20.431 Aufrufe
Nachricht 6 von 7
20.431 Aufrufe
Hi, thanks for your help but I´ve managed to solve this problem by myself. As you said, my pc is an old one and it runs a legacy bios. However, the solution was not easy and a little bit risky. I made a backup of my bios using "Intel ME System Tools v8 r3". Once I had my backup I proceeded to made the bios configuration proccessing the backup with "AMIBCP v4.53". Then I changed the PCI access configuration and that is the secret. Finally, I flash the modified bios and the mother board was able to recognize the new graphic card and It runs perfect! I want to share this here in order to help other people.
Thanks for your help!
6 ANTWORTEN 6
Gehringer
Retired
Nachricht 2 von 7
20.458 Aufrufe
Nachricht 2 von 7
20.458 Aufrufe
Hi @tl1000edu and welcome to the forum!
Your PC originally has an onboard graphic card.
For using it together with an external graphic card there are a few things you must do first.
Please try the steps mentioned here
Regards,
Gehringer
tl1000edu
Nachricht 3 von 7
20.452 Aufrufe
Nachricht 3 von 7
20.452 Aufrufe
Hi, thanks for your quick reply! I´ve already read the thread you show me but that it isn´t my problem. I only need to use one monitor but I decided to upgrade my graphics installing the RX 550 card and it doesn´t work. I have a "no signal" message on the screen.  What can I do?
Nachricht 4 von 7
20.446 Aufrufe
Nachricht 4 von 7
20.446 Aufrufe
@tl1000edu
I do assume your PC is a bit older, delivered with Win 7 installed you still will have a legacy Bios instead of the newer UEFI Bios?
But check in your Bios if there is a VGA Graphic possibility to swap from Integrated Graphic (IGD) to an external (dedicated) graphic card.
The Radeon RX 550 has an UEFI Rom with GOP, and can not be recognized by a classical legacy Bios. You must find a acrd with an old legacy bios compatible Rom.
Nachricht 5 von 7
20.440 Aufrufe
Nachricht 5 von 7
20.440 Aufrufe
@tl1000edu
Here is the link for the MSI 7728 V2.0 PCB.
tl1000edu
Nachricht 6 von 7
20.432 Aufrufe
Nachricht 6 von 7
20.432 Aufrufe
Nahemoth
Nachricht 7 von 7
11.467 Aufrufe
Nachricht 7 von 7
11.467 Aufrufe
Hi,
 I'm facing the same problem, and I'm very interested in your solution. Could you please provide more details, and where can I get AMIBCP utility?
Many thanks
6 ANTWORTEN 6
