Problem with B360H4-EM mobo bios
4 REPLIES 4
geekwer
Visitor
Message 1 of 5
Message 1 of 5
Hi, I have a problem with my mobo B360H4. Sometimes my pc freezes, sometimes didint recognize graphics card. I have already 360H4W0X.115 bios version installed on my pc. I need never version of it, as I know, there exist version 1.16 but I cannot find it anywhere. (I found ones on this site - "00_Bios_b360h4em_v116_w", but it looks like it didnt work with device manager system updater). Can anyone help mi with newer bios version and installation? Thanks
My MD is MD34242/C778 and MS is 10022580.
Thanks for any help
1 ACCEPTED SOLUTION
Mastermind
Message 4 of 5
Message 4 of 5
Hi @geekwer ,
I now can provide the Bios version V 1.16,which can be updated via the device manager of your system.
As always I have to add the disclaimer, that for any errors, caused by the execution of this update, we don´ t accept any responsibility for damage or lost of data.
Cheers
4 REPLIES 4
Message 2 of 5
Message 2 of 5
@geekwer
Hello geekwer, welcome.
You say you look for V 1.16. then you refer to a version 116_w  you did find?  This seems to be the newest one like  @Major_ToM said in this post from January 2024
--> https://community.medion.com/t5/Desktop-PC-All-In-One/B360H4-EM-BIOS-CANT-FIND-ANYWHERE/td-p/138592/...
To get  th bios downloaded, mark it, make a right click and copy the whole line, and copy it directly into the address bar of a new  browser windows.
With this every way to flash it is possible.
First decompress it in a folder (right click on the zip, unpack to the folder ("00_Bios_b360h4em_v116_w\").
In there are all ways to flash it - in Windows or another way.
Maybe @Major_ToM can give you a littlle help there.
Cheers, daddle
Mastermind
Message 3 of 5
Message 3 of 5
Hi @daddle  & @geekwer ,
I´ll try to arrange a alternative version 1.16 to be updated via the dev manager and come back
Cheers
Mastermind
Message 4 of 5
Message 4 of 5
Hi @geekwer ,
Cheers
geekver2
Message 5 of 5
Message 5 of 5
It works, many thanks for your help! 🙂
4 REPLIES 4
