No usb headers on B460H6-EM how can i add one to the motherboard?
5 RÉPONSES 5
BB_404
Message 1 sur 6
1 360 Visites
Message 1 sur 6
1 360 Visites
Hello so the medion motherboard has no usb headers i would like to know how you could add more to the motherboard.
how can i add one of these to the motherboard? @daddle @Fishtown
5 RÉPONSES 5
Message 2 sur 6
1 352 Visites
Message 2 sur 6
1 352 Visites
@BB_404
Who says that?
Your picture will be authorized only tomorrow morning, so I can  not see it right now.
But if you want to add more USB ports than the already existing 6 external USB ports, (2 in Front, 4 in backpanel) you can add a PCIe card into the PCIe x1 slot with USB ports in the slot bracket.
Cheers, daddle
BB_404
Message 3 sur 6
1 350 Visites
Message 3 sur 6
1 350 Visites
I meant if its possible to add in internal usb 2.0 headers
Message 4 sur 6
1 340 Visites
Message 4 sur 6
1 340 Visites
@BB_404
The Board has two internal USB headers. But your text is contradictionary. You write first  the mainboard has no USB headers, but then you talk about adding more USB headers?
 How should that work? You want to solder more headers onto the mainbard, not even knowing the circuitry of the mainboard (none of us does)? This can never work.
BB_404
Message 5 sur 6
1 325 Visites
Message 5 sur 6
1 325 Visites
My bad sorry for explaining wrong. I meant that there is no 9 pin usb headers, is there a way i can buy something to add one?
Balises (1)
Message 6 sur 6
1 318 Visites
Message 6 sur 6
1 318 Visites
@BB_404
What  a nuisance. You can not just add a new  USB header to a Mainboard.
These are the internal connectors:
Internal Connectors:
  • * 4 x SATA 3 ports (4x black color)
  • * 1 x M.2 M2_1 (2260 and 2280 size with flexible standoff, SATA mode only)
  • * 1 x M.2 M2_2 (for PCIe X4 NVMe SSD and Intel Optane module 2260 & 2280)
  • * 1 x M.2 M2_3 (E-Key 2230 for WLAN only)
  • * 1 x CPU 4PIN Fan header CPU_FAN (red)
  • * 1 x Sys FAN 4PIN SYS_FAN (white)
  • * 1 x Front Audio F_AUDIO with black plastic header
  • * 1 x Frontside USB: Cardreader with black plastic header (one port only),
  • * 1 x USB3.0 H10x2 front header F_USB31_12 (Intel pin out)
  • * 1 x Front_Panel header F_PANEL black plastic header
  • * 1 x 8PIN ATX 12V connector ATX_12V
5 RÉPONSES 5
