Medion S22003 bluetooth and wifi drivers
6 REPLIES 6
rebok
Message 1 of 7
Message 1 of 7
Hi, i just bought a used Medion S22003 mini pc. But it
seems like there isn't much data about it. What bluetooth
and wifi hardware does it use? With what is it connected with
to the motherboard? And if someone knows, then how to
configure it on linux?
1 ACCEPTED SOLUTION
rebok
Message 7 of 7
Message 7 of 7
No, that wasn't the reason why was it sold.
I returned it today and i'll buy another unit.
6 REPLIES 6
rebok
Message 2 of 7
Message 2 of 7
hmm, the card doesn't even show up when i run `lspci`(list pci devices)
Message 3 of 7
Message 3 of 7
@rebok
Officially Linux isn't supported.
Your PC has those specs:
https://www.medion.com/de/service/product-detail/10023733
You can enter your MSN Nummer there as well.  But the specs will be the same.
And name the MSN number  here as well.
Cheers, daddle
rebok
Message 4 of 7
Message 4 of 7
I mean it doesn't even work with all drivers updated on windows 10.
rebok
Message 5 of 7
Message 5 of 7
I got a used model with Intel ax201ngw installed
Message 6 of 7
Message 6 of 7
@rebok
  • Then  buy a new one and replace it,
The specs say it is a   WLAN Intel AC3165 SP AC+BT M.2 NGWG built in.
You bought a used Mini pc; furthermore diagnostic incl.  a hardware repair in the forum is not possible. May be thats why it was sold?
Sorry.
rebok
Message 7 of 7
Message 7 of 7
6 REPLIES 6
