Motherboard 3 short beeps
12 RÉPONSES 12
Simpsonni
Message 1 sur 13
7 580 Visites
Message 1 sur 13
7 580 Visites
Hi.
Just bought a motherboard and it gives 3 short beeps because ram error. It works with only when there is ram on slot 2 but when there is ram in slot 1 it doesn't show video and beeps.I have tried cleaning the DIM spot but doesn't seem to help. Ram sticks are not the problem neither.
What can I try to solve my problem?
ECS B360H4-EM MOTHERBOARD
https://pcmaestro.ie/product/ecs-b360h4-em-motherboard/
12 RÉPONSES 12
Simpsonni
Message 11 sur 13
1 725 Visites
Message 11 sur 13
1 725 Visites
Thanks for nothing. I have told multiple times that ram modules are not the problem. There is something wrong with the motherboard. I won't be buying a medion device ever again or will i use this forum where the admin or whatever can't even read. Insane Chinese garbage sold from Germany. Bye!
Simpsonni
Message 12 sur 13
1 724 Visites
Message 12 sur 13
1 724 Visites
Thanks for the bios. Would be more helpful if your team could make a website where you could download these without asking a million quoestion. Thanks!
Message 13 sur 13
1 720 Visites
Message 13 sur 13
1 720 Visites
@Simpsonni
You are getting quite insulting. I can read. Second I am not a Medion  employee. As I said before, I am just aUser like you. Just a bit better informed.
Except for this, your english is not very clear, often the references are set wongly. Grammar is mixed up and hard to understand.,
If a module functions in one memory slot, but not in the other, most probably there is a defect in the memory slot, which  is not bios dependant. Or it is a wrong modul, or it is defective itself.  A newer Bios will not cure this. You will see after flashing.
And if you do not stop to be aggressiv or insulting, you might  get a warning from the admins.
12 RÉPONSES 12
