Medion MSN10024693 MD34805 Engineer, storage upgrade and ram
4 RÉPONSES 4
baker2k1
Message 1 sur 5
1 524 Visites
Message 1 sur 5
1 524 Visites
Hi, just purchased this pc, and we are wanting to add more storage, can anyone recommend what SSD I need, I would like it to be a 2tb and fast as possible. Can't seem to find any information on spare slots/motherboard.
Also going to add another 16gb ram, can someone confirm type etc
Thanks Screenshot_2023-11-18-20-45-00-89_260528048de7f2f358f0056f785be619.jpg
for your help
Balises (1)
4 RÉPONSES 4
Message 2 sur 5
1 520 Visites
Message 2 sur 5
1 520 Visites
Hello @baker2k1 and welcome
Your pictures have not yet been released to us.
You have: 2x 8 GB DDR4-SDRAM (PC4-25600 / 3200 MHz) Dual Channel Memory
and can do up to: 2/4 Slots covered; 128 GB max. gear up.
An M.2 SSD 512GB PCie Gen 4.0x4 is installed and you can install another M.2 SSD PCIe in the free slot.
bye Fishtown
baker2k1
Message 3 sur 5
1 512 Visites
Message 3 sur 5
1 512 Visites
Hi thanks for the quick reply I'll go ahead and order a 2tb nvme drive to go along side the 500gb already loaded. Thanks
baker2k1
Message 4 sur 5
1 475 Visites
Message 4 sur 5
1 475 Visites
Hi again, so we've added a new SSD and all good, however I tried to add some extra ram, exact same spec as the current, but after fitting windows loads up and then says it's encountered an error and says it needs a restart with various errors coming up on the blue screen. Taken the ram back out and all ok, can it accept 4x8gb?
Message 5 sur 5
1 291 Visites
Message 5 sur 5
1 291 Visites
Hi @baker2k1 ,
your mainboard is equipped with Hynix DDR4-3200 HMA81GU6DJR8N RAM modules so you have to assure, that similar or equivalent modules are used.
As already mentioned the mainboard can take 128 GB RAM max.
Cheers
4 RÉPONSES 4
