Wake on LAN on desktop
2 REPLIES 2
iGPR
Message 1 of 3
Message 1 of 3
Hi! I would like to use WOL on my old PC, but I can't find a setting in the BIOS anywhere (at least I don't think I can, if anyone has the name of what I need to enable then that'd be great and I can triple check it). The motherboard is the BH460H6-EM. BIOS version is either of these, I'm not sure which as it says 2.21.1278 at the bottom and states the version is also 460H6W0X.105 x64 in the "main" section. It would be greatly appreciated if anyone could help. Thanks.
EDIT: The computer wakes from sleep, but not completely powered off. I'm not sure if this is just because the motherboard needs power or if it's an issue with the BIOS not allowing it to wake it from powered off.
1 ACCEPTED SOLUTION
Message 2 of 3
Message 2 of 3
Hi @iGPR and welcome
the same board B460H6-EM, look here:
https://community.medion.com/t5/ERAZER-Gaming/ERAZER-Engineer-P10-Wake-On-Lan/m-p/130780#M307
helpfull, look here:
https://www.ecs.com.tw/en/faq-detail/8-2006032018
bye Fishtown
2 REPLIES 2
Message 2 of 3
Message 2 of 3
bye Fishtown
iGPR
Message 3 of 3
Message 3 of 3
Thanks! All I had to do was disable UEP in the BIOS.
2 REPLIES 2
