Medion Erazer Engineer P10 randomly freezing
6 ANTWOORDEN 6
Braindead
Bericht 1 van 7
1.580 Weergaven
Bericht 1 van 7
1.580 Weergaven
Hi All,
 I have to work on my friend's Medion Erazer Engineer P10. Surprisingly there are 2 stickers on the back: first one says MD 34830 and MSN 10024811, nothing else. The other one says the product name, model name MT39, type name MED MT 8357N, ML-110000, MSN 10024651 and MD35262. That's two product code which is confusing but he second one seems the right one.
 Worked for two years (about) fine and last October (2025) problems started.
 Freezing, BSODs and then system repairing boot loop. That's how I got it. As I couldn't get the system out of the loop, I decided to reinstall the OS (Windows 11). Drivers up to date.
 Worked fine for two months then the same problem occured.
 Memory test ran without problem. GPU seems to work fine. Changed the NvME SSD to a different brand, different size to test. OS reinstalled.
 Now, after a month again working fine, I will get it back as crashes again. Sometimes during light-mid gaming with crackling noise or just simply dies on the owner. At the moment it seems like running but with black screen and moving cursor only and no response.
 Do you have any ideas?
 I'm thinking about the motherboard dying (or a CPU problem), an ageing PSU or - as the latest drivers are from 2022, from Medion's website - incompatibility problem (latest OS (Windows 11 25H2 or even 24H2) contra old motherboard/chipset drivers from the driver package.
 It has a Gigabyte B660M DS3H AX, Intel 12th i7-12700F, 16GB DDR4. The motherboard's BIOS version is 103 which is a custom Medion not a factory Gigabyte, which starts with an F. The BIOS date is 12/26/2022 which is - I think - the latest one. The video card is a Zotac GeForce RTX 3060 8GB, the original NvME was an 1 TB Phison, and the PSU is a 650W InWin BE B65E.
Thanks in advance
6 ANTWOORDEN 6
Bericht 2 van 7
1.568 Weergaven
Bericht 2 van 7
1.568 Weergaven
@Braindead
Hi. the MSN 10024651 (MD35262) is a originally P10 for the Netherlands.
--> https://www.medion.com/de/service/product-detail/10024651
The MSN 10024811 (MD 34830) is  a UK model called  ERAZER Engineer X10 (MD 34830) UK.
--> https://www.medion.com/de/service/product-detail/10024811
They are technically almost similar,  just the mainboards differ in version (important for a Bios Update)
MSN 10024811
MB GIGABYTE B660M DS3H AX DDR4 (MB MSN  20069821)
GIGABYTE B660M DS3H AX DDR4 1.2 AX211
(MB MSN 20070466
You can look on partition D (or E:\ or even C:\) for the file swconf.dat  In it you find the valid MSN
bye, daddle
Braindead
Bericht 3 van 7
1.565 Weergaven
Bericht 3 van 7
1.565 Weergaven
@daddle
Hi, thanks for the reply.
Is this file part of the OS or should it be on the original factory install drive? Because the original NvME was replaced and the OS was installed from scratch.
Bericht 4 van 7
1.539 Weergaven
Bericht 4 van 7
1.539 Weergaven
@Braindead
Yes, it comes with the original disk. on one of the partitions named. If you still own the original one, you can make use of an PCie (NVMe) adapter to USB or directly an external housing, which allows to use the old M.2 as an external disk)
But you can check with msinfo32.exe (Win Tab plus R --> msinfo32.exe --> Enter
On the first page in the line System-SKU the MSN ar the last 8 digit numbers
Also you will find the Bios Date in th eline Bios Version/ -date .
Bericht 5 van 7
1.528 Weergaven
Bericht 5 van 7
1.528 Weergaven
Hello @Braindead and welcome!
There's a new BIOS available: https://cdn.medion.com/downloads/anleitungen/BIOS_UPDATE_GIGABYTE_B660M_EN.pdf
But that won't fix your problem. And I would only install that once the problem is fixed.
It might be the RAM; you have two modules. Try using one at a time to see if it still crashes.
bye Fishtown
Bericht 6 van 7
1.521 Weergaven
Bericht 6 van 7
1.521 Weergaven
@Braindead
Das hilft ja richtig weiter. Das neue Bios habe ich absichtlich nicht empfohlen, das ich in dem Rechnerzustand mit der Gefahr eines Crashes, warum auch immer, keine Systemfirmware neu aufspielen würden
Und zweitens du scheibst  doch  glaubwürdig und kompetentt, dass du auch den RAM schon getestet hattest..
Dann  nehme ich nicht an du hättest nur einen Riegel sondern die  zwei vorhandenen getestet., auch mit Herausnahme je eines Riegels
Was du ergänzend machen solltest wäre  die Ramriegel jeweils im anderem Slot einstecken und testen.
Gruß, daddle
Braindead
Bericht 7 van 7
762 Weergaven
Bericht 7 van 7
762 Weergaven
Hi @Fishtown ,
Thanks for the BIOS update.
RAM modules were tested per each and together as well.
At the moment I'm trying to narrow the possible fault. As surprisingly the power supply is an entry level budget one, I replaced it with a branded one to see if that solves the problem.
It's been almost a month now since my friend uses it, so fingers crossed.
 So again: the full configuration worked fine for about a year and a half, low-, mid level online gaming. Then started to freeze and got a boot loop. Couldn't get out of the loop, I thought it might have been an OS update glitch, as 'normal' for Windows. Reinstalled the OS, worked fine for two months - not everyday usage - but then it started to glitch again with the same thing. So I replaced the NvME just for testing. After a month problems came again, but a bit different. Turned out that he replacement drive had bad sectors, so replaced again plus replaced the PSU. That's where we are now.
Any ideas much appreciated, thanks.
6 ANTWOORDEN 6
