MS 7633 REV 2.O bios file
15 REPLIES 15
art247
Message 1 of 16
Message 1 of 16
hi everyone!
I have the medion/MSI motherboard MS 7633 REV 2.O ( msn= 20046213) and have found the product page here- https://www.medion.com/gb/service/product-detail/20046213
but unfortunately I can't see any drivers or bios files there available to download! and it's the same on another older medion site where they are meant to be as well! I'm trying to add a newer video card to it (the GTX 750ti) but it won't display on boot (I had a similar thing on an old dell a few years ago where it needed a newer bios to run a 1050ti. I'm guessing it's going to be very hard to find! if anyone has any idea please where I can get it from let me know!!! thanks
Tags (1)
15 REPLIES 15
art247
Message 2 of 16
Message 2 of 16
This is the current bios I have. A7633MLN.20B
Message 3 of 16
Message 3 of 16
hi @art247
You should name the MSN of your PC; that gives a better chance to find drivers and evtl. a newer Bios,  only for PCs. For mainboards are no drivers and Bios Updates listed, if at all.
The more modern graphic cards have a GOP support, which goes with a UEFI Bios. Your  PC is too old fo rnewer cards, or you manage to get for modern cards an old legacy compatible graphic card bios.
cheers, daddle
art247
Message 4 of 16
Message 4 of 16
I did put the MSN number above or do you mean the actual model number? if so I got the item as a bare motherboard only so I'm unsure!! although it points to being a "MEDION PC MT14".
Message 5 of 16
Message 5 of 16
@art247
I do think I made it quite clear. To get drivers and Bios Updates, they are  Pc dependent.   The MSN you gave is for the motherboard, But in which PC was it built in? You say MT14.
There where you found this "name", often also the PC MSN is given, or an article number.  It should be 8 digits long, starting with 100.....  !
art247
Message 6 of 16
Message 6 of 16
I don't have that MSN unfortunately only the one from the motherboard so I guess I'm out of luck then! Thanks anyway
Message 7 of 16
Message 7 of 16
@art247
Maybe a moderator can help you
@Major_ToM
Is there a  newer  Bios or Update for the  MSI motherboard MS 7633 REV 2.O ( MSN = 20046213) than
Version A7633MLN.20B, Date 06/10/2020 (in Germany 10. Juni 2010)..
Thanks for your effort.
Bye, daddle
With addressing him, he is already informed.
art247
Message 8 of 16
Message 8 of 16
Thanks
Message 9 of 16
Message 9 of 16
@Major_ToM
Reminder-
@daddle  schrieb:
@art247
@Major_ToM
Is there a  newer  Bios or Update for the  MSI motherboard MS 7633 REV 2.O ( MSN = 20046213) than Version A7633MLN.20B,
Date 06/10/2020 (in german  10. Juni 2010)..
art247
Message 10 of 16
Message 10 of 16
I have seen newer D and E versions online in hardware benchmarks (instead of the B version I have of the bios) so they do exist but it's just IF anyone still has the file which seems unlikely!. I'm resigned to buying another motherboard now as I normally can resolve these things myself, it being OEM and not widespread makes it really hard finding stuff like this unfortunately. I'd probably be better off with an asus or gigabyte consumer board I guess. It's only for an old retro rig anyway.
15 REPLIES 15
